Abstract : The synchronous dataflow model is widely used
to design real-time streaming applications which must assure a
minimum quality-of-service. A benefit of that model is to allow
static analyses to predict and guarantee timing (e.g., throughput) and buffering requirements of an application. Performance
analyses can either be performed at compile time (for design
space exploration) or at run-time (for resource management and
reconfigurable systems). However, these algorithms, which often
have an exponential time complexity, may cause a huge runtime overhead or make design space exploration unacceptably
slow. In this paper, we argue that symbolic analyses are more
appropriate since they express the system performance as a
function of parameters (i.e., input and output rates, execution
times). Such functions can be quickly evaluated for each different
configuration or checked w.r.t. many different non-functional
requirements. We first provide a symbolic expression of the
maximal throughput of acyclic synchronous dataflow graphs. We
then perform an analytic and exact study of the minimum buffer
sizes needed to achieve this maximal throughput for a single
parametric edge graph. Based on these investigations, we define
symbolic analyses that approximate the minimum buffer sizes
needed to achieve maximal throughput for acyclic graphs. We
assess the proposed analyses experimentally on both synthetic
and real benchmarks.
