Learning Situation Models in a Smart Home - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Systems, Man, and Cybernetics, Part B: Cybernetics Année : 2008
This article addresses the problem of learning situation models for providing context-aware services. Context for modeling human behavior in a smart envi- ronment is represented by a situation model describing environment, users and their activities. A framework for acquiring and evolving different layers of a situation model in a smart environment is proposed. Different learning methods are presented as part of this framework: role detection per entity, unsupervised extraction of situations from multimodal data, supervised learning of situation representations, and the evolution of a predefined situation model with feedback. The situation model serves as frame and support for the different methods, permitting to stay in an intuitive declarative framework. The proposed methods have been integrated into a whole system for smart home environment. The implementation is detailed and two evaluations are conducted in the smart home environment. The obtained results validate the proposed approach.
article_smc-b_brdiczka-final.pdf (22.94 Mo) Télécharger le fichier
hal-01253466 , version 1 (11-01-2016)
  • HAL Id : hal-01253466 , version 1
Oliver Brdiczka, James L. Crowley, Patrick Reignier. Learning Situation Models in a Smart Home. IEEE Transactions on Systems, Man, and Cybernetics, Part B: Cybernetics, 2008, 39 (1), pp.56-63. ⟨hal-01253466⟩
456 Consultations
716 Téléchargements
