Algal productivity modeling: A step toward accurate assessments of full-scale algal cultivation
Quentin Béchet 1, 2 Paul Chambonnière 2 Andy Shilton 2 Guillaume Guizard 3 Benoit Guieysse 2
1 BIOCORE - Biological control of artificial ecosystems
LOV - Laboratoire d'océanographie de Villefranche, CRISAM - Inria Sophia Antipolis - Méditerranée , INRA - Institut National de la Recherche Agronomique
Abstract : A new biomass productivity model was parameterized for Chlorella vulgaris using short-term (<30min) oxygen productivities from algal microcosms exposed to 6 light intensities (20-420W/m(2)) and 6 temperatures (5-42 degrees C). The model was then validated against experimental biomass productivities recorded in bench-scale photobioreactors operated under 4 light intensities (30.6-74.3W/m(2)) and 4 temperatures (10-30 degrees C), yielding an accuracy of +/- 15% over 163 days of cultivation. This modeling approach addresses major challenges associated with the accurate prediction of algal productivity at full-scale. Firstly, while most prior modeling approaches have only considered the impact of light intensity on algal productivity, the model herein validated also accounts for the critical impact of temperature. Secondly, this study validates a theoretical approach to convert short-term oxygen productivities into long-term biomass productivities. Thirdly, the experimental methodology used has the practical advantage of only requiring one day of experimental work for complete model parameterization. The validation of this new modeling approach is therefore an important step for refining feasibility assessments of algae biotechnologies.
Type de document :
Article dans une revue
Biotechnology and Bioengineering, Wiley, 2015, 112 (5), pp.987-996. 〈10.1002/bit.25517〉
Liste complète des métadonnées
https://hal.inria.fr/hal-01253774
Contributeur : Jean-Luc Gouzé <>
Soumis le : lundi 11 janvier 2016 - 12:53:29
Dernière modification le : jeudi 11 janvier 2018 - 17:07:44
Collections
Citation
Quentin Béchet, Paul Chambonnière, Andy Shilton, Guillaume Guizard, Benoit Guieysse. Algal productivity modeling: A step toward accurate assessments of full-scale algal cultivation. Biotechnology and Bioengineering, Wiley, 2015, 112 (5), pp.987-996. 〈10.1002/bit.25517〉. 〈hal-01253774〉
Métriques
Consultations de la notice
204
