Use of fermentative metabolites for heterotrophic microalgae growth: Yields and kinetics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Bioresource Technology Année : 2015
The growth of two lipid-producing Chlorella species on fermentative end-products acetate, butyrate and lactate, was investigated using a kinetic modeling approach. Chlorella sorokiniana and Auxenochlorella protothecoides were grown on synthetic media with various (acetate:butyrate:lactate) ratios. Both species assimilated efficiently acetate and butyrate with yields between 0.4 and 0.5 g carbon of biomass/g carbon of substrate, but did not use lactate. The highest growth rate on acetate, 2.23 d−1, was observed for C. sorokiniana, and on butyrate, 0.22 d−1, for A. protothecoides. Butyrate removal started after complete acetate exhaustion (diauxic effect). However, butyrate consumption may be favored by the increase of biomass concentration induced by the initial use of acetate. A model combining Monod and Haldane functions was then built and fitted the experimental data well for both species. Butyrate concentration and (acetate:butyrate) ratios were identified as key parameters for heterotrophic growth of microalgae on fermentative metabolites.
OA_Turon_et_al_revised_BITE_14-04097R1.pdf (1.6 Mo) Télécharger le fichier
hal-01165732 , version 1 (07-08-2023)
Violette Turon, Caroline Baroukh, Eric Trably, Eric Latrille, Eric Fouilland, et al.. Use of fermentative metabolites for heterotrophic microalgae growth: Yields and kinetics. Bioresource Technology, 2015, 175, pp.342-349. ⟨10.1016/j.biortech.2014.10.114⟩. ⟨hal-01165732⟩
238 Consultations
32 Téléchargements
