Image segmentation with multidimensional refinement indicators, Inverse Problems in Science and Engineering, vol.10, issue.5, pp.577-597, 2011. ,
DOI : 10.1088/0266-5611/18/3/317
URL : https://hal.archives-ouvertes.fr/inria-00533799
Refinement and coarsening indicators for adaptive parametrization: application to the estimation of hydraulic transmissivities, Inverse Problems, vol.18, issue.3, p.775, 2002. ,
The multidimensional refinement indicators algorithm for optimal parameterization, Journal of Inverse and Ill- Posed Problems, pp.107-126, 2008. ,
On the theory and practice of non-linear least-squares, Advances in Water Resources, vol.14, issue.2, pp.55-63, 1991. ,
DOI : 10.1016/0309-1708(91)90051-O
Nonlinear Least Squares for Inverse Problems : Theoretical Foundations and Step-by=Step Guide for Applications, 2009. ,
DOI : 10.1007/978-90-481-2785-6
Multiscale parameterization for the estimation of a diffusion coefficient in elliptic and parabolic problems, 5th IFAC Symposium on Control of Distributed Parameter Systems, pp.26-29, 1989. ,
A method of estimating parameters and assessing reliability for models of steady state groundwater flow: 1. Theory and numerical properties, Water Resources Research, vol.7, issue.4, pp.318-324, 1982. ,
DOI : 10.1029/WR013i002p00318
40 years of inverse problems in hydrogeology. Comptes Rendus de l'Academie des Sciences Series IIA Earth and Planetary Science, pp.73-87, 1999. ,
Simultaneous Estimation of Transmissivity Values and Zonation, Water Resources Research, vol.33, issue.2, pp.3321-3336, 1996. ,
DOI : 10.1029/96WR02283
Adaptive multiscale permeability estimation, Computational Geosciences, vol.7, issue.1, pp.1-25, 2003. ,
DOI : 10.1023/A:1022417923824
An Adaptive Subdivision Algorithm for the Identification of the Diffusion Coefficient in Two-dimensional Elliptic Problems, Journal of Mathematical Modelling and Algorithms, vol.17, issue.3, pp.529-545, 2007. ,
DOI : 10.1007/s10852-006-9046-1
A new refinement indicator for adaptive parameterization: Application to the estimation of the diffusion coefficient in an elliptic problem, Journal of Computational and Applied Mathematics, vol.224, issue.1, pp.307-319, 2009. ,
DOI : 10.1016/j.cam.2008.05.006
A Multiresolution Method for Distributed Parameter Estimation, SIAM Journal on Scientific Computing, vol.14, issue.2, pp.389-405, 1993. ,
DOI : 10.1137/0914024
Inverse problems in groundwater modeling, 1994. ,
DOI : 10.1007/978-94-017-1970-4
A finite-element simulation model for saturated-unsaturated, fluid-densitydependent ground-water flow with energy transport or chemically-reactive single-species solute transport, US Geological Survey, vol.84, 1984. ,
Review of parameter identification procedures in groundwater hydrology : The inverse problem, Water Resources Research, vol.22, issue.2, pp.95-108, 1986. ,
