Abstract : Numerical simulations of non-newtonian fluids such as wormlike micellar solutions in confined geometries are of great interest in the oil industry. Their main property called shear-banding is a brutal transition from a very viscous
state to a very fluid state above a certain threshold value of shear stress. This feature leads to a very complex behavior in 3D flows. A modified version of the Johnson-Segalman’s model, adapted to our situation (flows with a strong extensional component) is presented. A particular attention is paid to inlet and outlet boundary conditions, and a Poiseuillelike submodel is derived in order to get natural velocity and stress profiles that can be used at the boundaries. A numerical method is then developed, and stability issues are presented. Our results show the interest of the modified Johnson-Segalman’s model performed in this article. A set of 3D numerical simulations are then presented
in order to understand the influence of the junction geometry upon the jamming effects observed in the behaviour of this kind of fluids.
https://hal.inria.fr/hal-01254642
Contributor : Mathieu Colin <>
Submitted on : Tuesday, January 12, 2016 - 3:14:10 PM Last modification on : Thursday, February 11, 2021 - 2:54:02 PM
