Conference papers
On shoaling properties of enhanced Boussinesq models
Abstract : In this paper, we investigate the nonlinear properties of Boussinesq models. In particular, we consider the wave shoaling obtained in physical regimes which go from linear to weakly nonlinear, to the wave breaking limit. For a given asymptotic accuracy in terms of dispersion and nonlinearity, we consider two families of models: the first depending on derivatives of the velocity, the second on derivatives of the volume flux. Ww show that, while linear dispersion and linear shoaling characteristics are strongly dependent on the type of dispersive terms introduced, when approaching the nonlinear regime the only influencing factor is whether the model is in amplitude-velocity of amplitude-flux form. We investigate these two alternative formulations of several known models, and propose a new model with a compact differential form, and the same linear characteristics of the model of Nwogu. The nonlinear shoaling properties of the models are investigated numerically showing that inside one given family, all the models have almost identical behaviour.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01254675
Contributor : Mathieu Colin Connect in order to contact the contributor
Submitted on : Tuesday, January 12, 2016 - 3:28:54 PM
Last modification on : Wednesday, February 2, 2022 - 3:54:30 PM
Identifiers
  • HAL Id : hal-01254675, version 1
Collections
Citation
Andrea Gilberto Filippini, Stevan Bellec, Mathieu Colin, Mario Ricchiuto. On shoaling properties of enhanced Boussinesq models. ECMI 2014 The 18th European Conference on Mathematics for Industry, Jun 2014, Taormina, Italy. ⟨hal-01254675⟩
Share
Metrics
Record views
74
