New interface
Other publications
Impact of Virtualization and SDN on Emerging Network Coding
Abstract : Network Coding is a technique used to code packets and be able to recover coded packets from loses. It requires at least two participating nodes in the path of the packet, one to encode and another to decode. This document discusses the impact of virtualization and Software-Defined Networking (SDN) on the emerging network coding. This document also discusses the integration of network coding in various layers of the network stack and the APIs required from the network coding entity to program it from a controller.
Keywords : network coding SDN
Document type :
Other publications
Complete list of metadata
https://hal.inria.fr/hal-01254894
Contributor : Cédric Adjih Connect in order to contact the contributor
Submitted on : Tuesday, January 12, 2016 - 6:01:40 PM
Last modification on : Friday, November 18, 2022 - 9:23:27 AM
Identifiers
  • HAL Id : hal-01254894, version 1
Citation
Bhumip Khasnabish, Senthil Sivakumar, Evangelos Haleplidis, Cédric Adjih. Impact of Virtualization and SDN on Emerging Network Coding. 2015. ⟨hal-01254894⟩
Share
Metrics
Record views
218
