Multichannel audio declipping
Abstract : Audio declipping consists in recovering so-called clipped audio samples that are set to a maximum / minimum threshold. Many different approaches were proposed to solve this problem in case of single-channel (mono) recordings. However, while most of audio recordings are multichannel nowadays, there is no method designed specifically for multichannel audio declipping, where the inter-channel correlations may be efficiently exploited for a better declipping result. In this work we propose for the first time such a multichannel audio declipping method. Our method is based on representing a multichannel audio recording as a convolutive mixture of several audio sources, and on modeling the source power spectrograms and mixing filters by nonnegative tensor factorization model and full-rank covariance matrices, respectively. A generalized expectation-maximization algorithm is proposed to estimate model parameters. It is shown experimentally that the proposed multichannel audio de-clipping algorithm outperforms in average and in most cases a state-of-the-art single-channel declipping algorithm applied to each channel independently.
Document type :
Conference papers
Complete list of metadatas
Cited literature [23 references]  Display  Hide  Download
https://hal.inria.fr/hal-01254950
Contributor : Alexey Ozerov <>
Submitted on : Thursday, January 14, 2016 - 3:38:42 PM
Last modification on : Wednesday, January 31, 2018 - 3:08:01 PM
Long-term archiving on : Tuesday, April 19, 2016 - 1:20:11 AM
File
icassp16b.pdf
Identifiers
  • HAL Id : hal-01254950, version 2
Citation
Alexey Ozerov, Cagdas Bilen, Patrick Pérez. Multichannel audio declipping. IEEE International Conference on Acoustics, Speech, and Signal Processing (ICASSP'16), Mar 2016, Shanghai, China. ⟨hal-01254950v2⟩
Share
Metrics
Record views
197
Files downloads
310
