A Network Planning and Management Tool for Mitigating the Impact of Spatially Correlated Failures in Infrastructure Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Current practices of fault-tolerant network design ignore the fact that most network infrastructure faults are localized or spatially correlated (i.e., confined to regions). Network operators require new tools to mitigate the impact of such region based faults on their infrastructures. Utilizing the support from the U.S. Department of Defense, and by consolidating a wide range of theories and solutions developed in the last few years, the authors of this paper have developed an advanced Network Planning and Management Tool (NPMT) that facilitates the design and provisioning of robust and resilient networks. The tool provides multifaceted network design, evaluation and simulation capabilities for network planners. Future extensions of the tool currently being worked upon not only expand the tool's capabilities, but also extend these capabilities to heterogeneous interdependent networks such as communication, power, water and satellite networks.
1570223866-2.pdf (7.58 Mo) Télécharger le fichier
hal-01254982 , version 1 (21-03-2016)
  • HAL Id : hal-01254982 , version 1
Arun Das, Arunabha Sen, Chunming Qiao, Nasir Ghani, Nathalie Mitton. A Network Planning and Management Tool for Mitigating the Impact of Spatially Correlated Failures in Infrastructure Networks. International Conference on Design of Reliable Communication Networks (DRCN), Mar 2016, Paris, France. ⟨hal-01254982⟩
Collections
INRIA INRIA2
154 Consultations
186 Téléchargements
