The hyper-deBruijn networks: scalable versatile architecture, IEEE Transactions on Parallel and Distributed Systems, vol.4, issue.9, 1993. ,
DOI : 10.1109/71.243525
Fault-Tolerance in Sensor Networks: A New Evaluation Metric, Proceedings IEEE INFOCOM 2006. 25TH IEEE International Conference on Computer Communications, pp.1-12, 2006. ,
DOI : 10.1109/INFOCOM.2006.270
Network Reliability With Geographically Correlated Failures, 2010 Proceedings IEEE INFOCOM, pp.1-9, 2010. ,
DOI : 10.1109/INFCOM.2010.5461984
Optimised heuristics for a geodiverse routing protocol, 2014 10th International Conference on the Design of Reliable Communication Networks (DRCN), pp.1-9, 2014. ,
DOI : 10.1109/DRCN.2014.6816133
The resilience of wdm networks to probabilistic geographical failures, Proceedings of IEEE INFOCOM, 2011. ,
Finding Critical Regions and Region-Disjoint Paths in a Network, IEEE/ACM Transactions on Networking, vol.23, issue.3, pp.908-921, 2015. ,
DOI : 10.1109/TNET.2014.2309253
On the impact of coding parameters on storage requirement of region-based fault tolerant distributed file system design, 2014 International Conference on Computing, Networking and Communications (ICNC), pp.78-82, 2014. ,
DOI : 10.1109/ICCNC.2014.6785309
Region based fault-tolerant distributed file storage system design under budget constraint, 2014 6th International Workshop on Reliable Networks Design and Modeling (RNDM), pp.61-68, 2014. ,
DOI : 10.1109/RNDM.2014.7014932
Region-based fault-tolerant distributed file storage system design in networks, Networks, vol.19, issue.4, 2015. ,
DOI : 10.1002/net.21655
Region-based connectivity - a new paradigm for design of fault-tolerant networks, 2009 International Conference on High Performance Switching and Routing, pp.1-7, 2009. ,
DOI : 10.1109/HPSR.2009.5307417
Beyond connectivity - new metrics to evaluate robustness of networks, 2011 IEEE 12th International Conference on High Performance Switching and Routing, pp.171-177, 2011. ,
DOI : 10.1109/HPSR.2011.5986022
Design and Analysis of Networks with Large Components in Presence of Region-Based Faults, 2011 IEEE International Conference on Communications (ICC), 2011. ,
DOI : 10.1109/icc.2011.5962427
Catastrophic cascade of failures in interdependent networks, Nature, vol.80, issue.7291, pp.1025-1028, 2010. ,
DOI : 10.1038/nature08932
Networks formed from interdependent networks, Nature Physics, vol.5, issue.1, pp.40-48, 2011. ,
DOI : 10.1103/PhysRevE.74.011122
Interdependent Multi-Layer Networks: Modeling and Survivability Analysis with Applications to Space-Based Networks, PLoS ONE, vol.94, issue.11, p.60402, 2013. ,
DOI : 10.1371/journal.pone.0060402.t002
Identification of K most vulnerable nodes in multi-layered network using a new model of interdependency, 2014 IEEE Conference on Computer Communications Workshops (INFOCOM WKSHPS), pp.831-836, 2014. ,
DOI : 10.1109/INFCOMW.2014.6849338
Root Cause Analysis of Failures in Interdependent Power-Communication Networks, 2014 IEEE Military Communications Conference, pp.910-915, 2014. ,
DOI : 10.1109/MILCOM.2014.156
On the Entity Hardening Problem in multi-layered interdependent networks, 2015 IEEE Conference on Computer Communications Workshops (INFOCOM WKSHPS), pp.648-653, 2015. ,
DOI : 10.1109/INFCOMW.2015.7179459
On the smallest pseudo target set identification problem for targeted attack on interdependent power-communication networks, MILCOM 2015, 2015 IEEE Military Communications Conference, 2015. ,
DOI : 10.1109/MILCOM.2015.7357578
On Robustness in Multilayer Interdependent Networks, Conference on Critical Information Infrastructures Security (CRITIS), 2015. ,
DOI : 10.1007/978-3-319-33331-1_21
Progressive Recovery from Failure in Multi-layered Interdependent Network Using a New Model of Interdependency, Conference on Critical Information Infrastructures Security (CRITIS, 2014. ,
DOI : 10.1007/978-3-319-31664-2_38
