The Zeiss-Nomarski differential interference equipment for transmitted-light microscopy, Z. Wiss. Mikrosk, vol.69, issue.4, pp.193-221, 1969. ,
Theoretical development and experimental evaluation of imaging models for differential-interference-contrast microscopy, Journal of the Optical Society of America A, vol.16, issue.9, pp.2185-2199, 1999. ,
DOI : 10.1364/JOSAA.16.002185
Fundamentals of light microscopy and electronic imaging, 2001. ,
DOI : 10.1002/9781118382905
P-58: Accelerating Phase Shifting Technique in Quantitative Differential Interference Contrast System for Critical Dimension Measurement of TFT Substrate, SID Symposium Digest of Technical Papers, vol.13, issue.1, 2012. ,
DOI : 10.1002/j.2168-0159.2012.tb06034.x
Phase retrieval by using transport-ofintensity equation and differential interference contrast microscopy, Proc. 21th IEEE International Conference on Image Processing, pp.3939-3943, 2014. ,
Rotational-diversity phase estimation from differential-interference-contrast microscopy images, Journal of the Optical Society of America A, vol.17, issue.3, pp.415-424, 2000. ,
DOI : 10.1364/JOSAA.17.000415
A limited memory steepest descent method, Mathematical Programming, vol.24, issue.1-2, pp.413-436, 2012. ,
DOI : 10.1007/s10107-011-0479-6
Analysis of bounded variation penalty methods for ill-posed problems, Inverse Problems, vol.10, issue.6, pp.1217-1229, 1994. ,
DOI : 10.1088/0266-5611/10/6/003
Two-Point Step Size Gradient Methods, IMA Journal of Numerical Analysis, vol.8, issue.1, pp.141-148, 1988. ,
DOI : 10.1093/imanum/8.1.141
Gradient Methods with Adaptive Step-Sizes, Computational Optimization and Applications, vol.14, issue.1, pp.69-86, 2006. ,
DOI : 10.1007/s10589-006-6446-0
Limited-memory scaled gradient projection methods for real-time image deconvolution in microscopy, Communications in Nonlinear Science and Numerical Simulation, vol.21, issue.1-3, pp.1-3, 2015. ,
DOI : 10.1016/j.cnsns.2014.08.035
A New Steplength Selection for Scaled Gradient Methods with Application to Image Deblurring, Journal of Scientific Computing, vol.47, issue.3 ,
DOI : 10.1007/s10915-015-9991-9
