New interface
Journal articles
An entropy preserving relaxation scheme for ten-moments equations with source terms
Abstract : The present paper concerns the derivation of finite volume methods to approximate weak solutions of Ten-Moments equations with source terms. These equations model compressible anisotropic flows. A relaxation-type scheme is proposed to approximate such flows. Both robustness and stability conditions of the suggested finite volume methods are established. To prove discrete entropy inequalities, we derive a new strategy based on local minimum entropy principle and never use some approximate PDE's auxiliary model as usually recommended. Moreover, numerical simulations in 1D and in 2D illustrate our approach.
Complete list of metadata
Cited literature [36 references]  Display  Hide  Download
https://hal.inria.fr/hal-01255069
Contributor : Afeintou SANGAM Connect in order to contact the contributor
Submitted on : Friday, January 15, 2016 - 10:44:27 AM
Last modification on : Sunday, November 27, 2022 - 2:48:05 PM
Long-term archiving on: : Saturday, April 16, 2016 - 10:10:44 AM
File
bds10mom.pdf
Identifiers
Citation
Christophe Berthon, Bruno Dubroca, Afeintou Sangam. An entropy preserving relaxation scheme for ten-moments equations with source terms. Communications in Mathematical Sciences, 2015, Communications in Mathematical Sciences, 13 (8), pp. 2119-2154. ⟨10.4310/CMS.2015.v13.n8.a7⟩. ⟨hal-01255069⟩
Share
Metrics
Record views
300
Files downloads
175
