The physics of Inertial Fusion, Beam Plasma Interaction, Hydrodynamics , Hot Dense Matter, International Series of Monographs on Physics, 2009. ,
A relaxation method for two-phase flow models with hydrodynamic closure law, Numerische Mathematik, vol.48, issue.3, p.411, 2005. ,
DOI : 10.1007/s00211-004-0558-1
In??galit??s d'entropie pour un sch??ma de relaxation, Comptes Rendus Mathematique, vol.340, issue.1, pp.63-68, 2005. ,
DOI : 10.1016/j.crma.2004.10.008
Stability of the MUSCL Schemes for the Euler Equations, Communications in Mathematical Sciences, vol.3, issue.2, p.133, 2005. ,
DOI : 10.4310/CMS.2005.v3.n2.a3
Numerical approximations of the 10-moment Gaussian closure, Mathematics of Computation, vol.75, issue.256, pp.1809-1831, 2006. ,
DOI : 10.1090/S0025-5718-06-01860-6
An asymptotic preserving relaxation scheme for a moment model of radiative transfer, Comptes Rendus Mathematique, vol.344, issue.7, pp.467-472, 2007. ,
DOI : 10.1016/j.crma.2007.02.004
URL : https://hal.archives-ouvertes.fr/hal-00293560
A Local Entropy Minimum Principle for Deriving Entropy Preserving Schemes, SIAM Journal on Numerical Analysis, vol.50, issue.2, pp.468-491, 2012. ,
DOI : 10.1137/100814445
URL : https://hal.archives-ouvertes.fr/hal-01280691
Entropy satisfying flux vector splittings and kinetic BGK models, Numerische Mathematik, vol.94, issue.4, p.623, 2003. ,
DOI : 10.1007/s00211-002-0426-9
Nonlinear stability of finite volume methods for hyperbolic conservation laws, and well-balanced schemes for sources, Frontiers in Mathematics series, 2004. ,
Numerical solution of a 10-moment model for nonequilibrium gasdynamics, 12th Computational Fluid Dynamics Conference, 1995. ,
DOI : 10.2514/6.1995-1677
Un schéma numérique adapaté au modèle d'atmosphère avec termes de gravité, C. R., Acad. Sci. Paris, Ser. I, vol.318, pp.73-76, 1994. ,
Bilan d'entropie discrets dans l'approximation numérique des chocs non classics. Application auxéquationsauxéquations de N.S multi-pression 2D etàetà systèmes visco-capillaires, 2002. ,
Navier-Stokes equations with several independant pressure laws and explicit predictor-corrector schemes, Numerisch Math, pp.451-478, 2005. ,
DOI : 10.1007/s00211-005-0612-7
GODUNOV-TYPE SCHEMES FOR HYPERBOLIC SYSTEMS WITH PARAMETER-DEPENDENT SOURCE: THE CASE OF EULER SYSTEM WITH FRICTION, Mathematical Models and Methods in Applied Sciences, vol.20, issue.11, p.2109, 2010. ,
DOI : 10.1142/S021820251000488X
URL : https://hal.archives-ouvertes.fr/hal-00401616
Hyperbolic conservation laws with stiff relaxation terms and entropy, Communication in Pure and Applied Mathematics, p.787, 1995. ,
DOI : 10.1002/cpa.3160470602
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.50.312
Relaxation of Energy and Approximate Riemann Solvers for General Pressure Laws in Fluid Dynamics, SIAM Journal on Numerical Analysis, vol.35, issue.6, p.2223, 1998. ,
DOI : 10.1137/S0036142997318528
High-Energy-Density Physics, Fundamentals, Inertial Fusion, and Experimental Astrophysics , Shock Wave and High Pressure Phenomena, 2006. ,
Magnetic field generation in plasmas due to anisotropic laser heating, Physics of Plasmas, vol.11, issue.8, p.3830, 2004. ,
DOI : 10.1063/1.1760089
Etude numérique des systèmes aux moments de Lervermore pour la modélisation d'´ ecoulements bidimensionnels horséquilibrehorséquilibre cinétique, 1997. ,
Numerical Approximation of Hyperbolic Systems of Conservation Laws, Applied Mathematical Sciences, vol.118, 1996. ,
DOI : 10.1007/978-1-4612-0713-9
On Upstream Differencing and Godunov-Type Schemes for Hyperbolic Conservation Laws, SIAM Review, vol.25, issue.1, p.35, 1983. ,
DOI : 10.1137/1025002
The relaxation schemes for systems of conservation laws in arbitrary space dimensions, Pure and Applied Mathematics, p.235, 1995. ,
DOI : 10.1002/cpa.3160480303
The Physics of Laser Plasma Interactions, Frontiers in Physics, 2003. ,
Hyperbolic Systems of Conservation Laws and Mathematical Theory of Shock Waves, Conference Board of Mathematical Sciences Conference Series in Applied Mathematics, SIAM, vol.11, 1973. ,
Finite Volume Methods for Hyperbolic Problems, Cambridge Texts in Applied Mathematics, 2003. ,
DOI : 10.1017/CBO9780511791253
Moment closure hierarchies for kinetic theories, Journal of Statistical Physics, vol.23, issue.5-6, p.1021, 1996. ,
DOI : 10.1007/BF02179552
The Gaussian Moment Closure for Gas Dynamics, SIAM Journal on Applied Mathematics, vol.59, issue.1, p.72, 1996. ,
DOI : 10.1137/S0036139996299236
Hyperbolic Conservation Laws with Relation, Pure and Applied Mathematics, p.153, 1987. ,
Electron temperature anisotropy modeling and its effect on anisotropy-magnetic field coupling in an underdense laser heated plasma, Journal de Physique IV (Proceedings), vol.133, p.295, 2006. ,
DOI : 10.1051/jp4:2006133058
URL : https://hal.archives-ouvertes.fr/hal-00293558
Anisotropic instability in a laser heated plasma, Physics of Plasmas, p.53111, 2007. ,
An HLLC scheme for Ten-Moments approximation coupled with magnetic field, International Journal of Computing Science and Mathematics, vol.2, issue.1/2, p.73, 2008. ,
DOI : 10.1504/IJCSM.2008.019724
Energy estimates in rate-type thermo-viscoplasticity, International Journal of Plasticity, vol.14, issue.1-3, p.78, 1987. ,
DOI : 10.1016/S0749-6419(97)00053-3
A minimum entropy principle in the gas dynamics equations, Applied Numerical Mathematics, vol.2, issue.3-5, p.211, 1986. ,
DOI : 10.1016/0168-9274(86)90029-2
Restoration of the contact surface in the HLL-Riemann solver, Shock Waves, p.25, 1994. ,
Riemann Solvers and Numerical Methods for Fluids dynamics, A Pratical Introduction, 2009. ,
High Order Well-Balanced WENO Scheme for the Gas Dynamics Equations Under Gravitational Fields, Journal of Scientific Computing, vol.143, issue.2-3, pp.645-662, 2013. ,
DOI : 10.1007/s10915-012-9585-8
