New interface
Journal articles
A Mesh-Adaptive Metric-Based Full-Multigrid for the Poisson problem
Abstract : This paper studies the combination of the Full-Multi-Grid (FMG) algorithm with an anisotropic metric- based mesh adaptation algorithm. For the sake of simplicity, the case of an elliptic two-dimentional Partial Differential Equation (PDE) is studied. Meshes are unstructured and non-embedded, defined through the metric-based parametrisation. A rather classical MG preconditionner is applied, in combination with a quasi-Newton fixed point. An anisotropic metric-based mesh adaptation loop is introduced inside the FMG algorithm. FMG convergence stopping test is re-visited. Applications to a few 2D continuous and discontinuous-coefficient elliptic model problems show the efficiency of this combination.
Document type :
Journal articles
Complete list of metadata
Cited literature [22 references]  Display  Hide  Download
https://hal.inria.fr/hal-01255500
Contributor : Gautier Brèthes Connect in order to contact the contributor
Submitted on : Monday, January 18, 2016 - 2:04:14 PM
Last modification on : Saturday, June 25, 2022 - 11:18:02 PM
Long-term archiving on: : Friday, November 11, 2016 - 4:56:27 AM
File
article-ADA-MG.pdf
Identifiers
Collections
Citation
Gautier Brethes, Olivier Allain, Alain Dervieux. A Mesh-Adaptive Metric-Based Full-Multigrid for the Poisson problem. International Journal for Numerical Methods in Fluids, 2015, 79 (1), pp.30-53. ⟨10.1002/fld.4042⟩. ⟨hal-01255500⟩
Share
Metrics
Record views
106
Files downloads
123
