Digital volume correlation: Three-dimensional strain mapping using X-ray tomography, Experimental Mechanics, vol.27, issue.10???12, pp.217-226, 1999. ,
DOI : 10.1007/BF02323555
Digital image correlation used for mechanical tests on crimped glass wool samples, The Journal of Strain Analysis for Engineering Design, vol.32, issue.2, pp.185-197, 2005. ,
DOI : 10.1243/030932405X7773
URL : https://hal.archives-ouvertes.fr/hal-00013799
???Finite-Element??? Displacement Fields Analysis from Digital Images: Application to Portevin???Le Ch??telier Bands, Experimental Mechanics, vol.404, issue.3, pp.789-803, 2006. ,
DOI : 10.1007/s11340-006-9824-8
On the Propagation of Camera Sensor Noise to Displacement Maps Obtained by DIC - an Experimental Study, Experimental Mechanics, vol.45, issue.2, 2016. ,
DOI : doi:10.1002/nme.5212
URL : https://hal.archives-ouvertes.fr/hal-01269655
Interface debonding characterization by image correlation integrated with Double Cantilever Beam kinematics, International Journal of Solids and Structures, vol.55, pp.79-91, 2015. ,
DOI : 10.1016/j.ijsolstr.2014.06.012
Applications of digital-image-correlation techniques to experimental mechanics, Experimental Mechanics, vol.1, issue.3, pp.232-244, 1985. ,
DOI : 10.1007/BF02325092
Evaluation of accuracy and spatial resolution in high strain gradient fields, 1st International Digital Image Correlation Society Conference and Workshop, 2015. ,
Identification of a set of macroscopic elastic parameters in a 3D woven composite: Uncertainty analysis and regularization, International Journal of Solids and Structures, vol.55, pp.2-16, 2015. ,
DOI : 10.1016/j.ijsolstr.2013.12.023
URL : https://hal.archives-ouvertes.fr/hal-01166765
Full-field measurements and identification in solid mechanics, 2013. ,
DOI : 10.1002/9781118578469
Anniversary Article: Effect of Sensor Noise on the Resolution and Spatial Resolution of Displacement and Strain Maps Estimated with the Grid Method, Strain, vol.22, issue.1, pp.1-27, 2014. ,
DOI : 10.1111/str.12070
An Intermediate Course in Probability, 2009. ,
Comparison of Local and Global Approaches to Digital Image Correlation, Experimental Mechanics, vol.39, issue.8, pp.1503-1519, 2012. ,
DOI : 10.1007/s11340-012-9603-7
URL : https://hal.archives-ouvertes.fr/hal-00750756
International vocabulary of metrology ? Basic and general concepts and associated terms (VIM), BIPM, vol.200, 2012. ,
Error Assessment in Stereo-based Deformation Measurements, Experimental Mechanics, vol.46, issue.3, pp.423-441, 2011. ,
DOI : 10.1007/s11340-010-9450-3
On image gradients in digital image correlation, International Journal for Numerical Methods in Engineering, vol.49, issue.3, pp.243-260, 2016. ,
DOI : 10.1002/nme.4971
Comparison of Subset-Based Local and Finite Element-Based Global Digital Image Correlation, Experimental Mechanics, vol.38, issue.2, pp.887-901, 2015. ,
DOI : 10.1007/s11340-015-9989-0
A fully integrated noise robust strategy for the identification of constitutive laws from digital images, International Journal for Numerical Methods in Engineering, vol.199, issue.21-22, pp.631-660, 2010. ,
DOI : 10.1002/nme.2908
Experimental investigation of localized phenomena using digital image correlation, Philosophical Magazine, vol.364, issue.28-29, pp.28-293339, 2008. ,
DOI : 10.1002/nme.849
Extended digital image correlation with crack shape optimization, International Journal for Numerical Methods in Engineering, vol.47, issue.2, pp.248-272, 2008. ,
DOI : 10.1002/nme.2070
Stress intensity factor measurements from digital image correlation: post-processing and integrated approaches, International Journal of Fracture, vol.40, issue.1, pp.141-157, 2006. ,
DOI : 10.1007/s10704-006-6631-2
URL : https://hal.archives-ouvertes.fr/hal-00013818
Image correlation for shape, motion and deformation measurements: Basic Concepts, Theory and Applications, 2009. ,
DOI : 10.1007/978-0-387-78747-3
Handbook of Computer Vision and Applications, chapter Bayesian Multi- Scale Differential Optical Flow, 1998. ,
Sensor Noise Modeling by Stacking Pseudo-Periodic Grid Images Affected by Vibrations, IEEE Signal Processing Letters, vol.21, issue.4, pp.432-436, 2014. ,
DOI : 10.1109/LSP.2014.2304570
URL : https://hal.archives-ouvertes.fr/hal-00955709
Computing the Uncertainty of the 8 point Algorithm for Fundamental Matrix Estimation, Procedings of the British Machine Vision Conference 2008, pp.965-974, 2008. ,
DOI : 10.5244/C.22.96
URL : https://hal.archives-ouvertes.fr/inria-00319704
Effects Of Subpixel Image Restoration On Digital Correlation Error Estimates, Optical Engineering, vol.27, issue.10, p.271070, 1988. ,
DOI : 10.1117/12.7976778
Application of an optimized digital correlation method to planar deformation analysis, Image and Vision Computing, vol.4, issue.3, pp.143-150, 1986. ,
DOI : 10.1016/0262-8856(86)90057-0
Formulation of Lucas-Kanade Digital Image Correlation Algorithms for Non-contact Deformation Measurements: A Review, Strain, vol.23, issue.4, pp.313-334, 2013. ,
DOI : 10.1111/str.12039
Reduction of Noise-Induced Bias in Displacement Estimation by Linear Off-Pixel Digital Image Correlation, Strain, vol.36, issue.2, pp.158-166, 2013. ,
DOI : 10.1111/str.12023
Submicron deformation field measurements: Part 2. Improved digital image correlation, Experimental Mechanics, vol.38, issue.1, pp.86-92, 1998. ,
DOI : 10.1007/BF02321649
Quantitative Error Assessment in Pattern Matching: Effects of Intensity Pattern Noise, Interpolation, Strain and Image Contrast on Motion Measurements, Strain, vol.47, issue.2, pp.45160-178, 2009. ,
DOI : 10.1111/j.1475-1305.2008.00592.x
On Error Assessment in Stereo-based Deformation Measurements, Experimental Mechanics, vol.51, issue.4, pp.405-422, 2011. ,
DOI : 10.1007/s11340-010-9449-9
Statistical Analysis of the Effect of Intensity Pattern Noise on the Displacement Measurement Precision of Digital Image Correlation Using Self-correlated Images, Experimental Mechanics, vol.43, issue.6, pp.47701-707, 2007. ,
DOI : 10.1007/s11340-006-9005-9
A Self Adaptive Global Digital Image Correlation Algorithm, Experimental Mechanics, vol.48, issue.6, pp.361-378, 2015. ,
DOI : 10.1007/s11340-014-9946-3
Using Image Gradients to Improve Robustness of Digital Image Correlation to Non-uniform Illumination: Effects of Weighting and Normalization Choices, Experimental Mechanics, vol.17, issue.6, pp.963-979, 2015. ,
DOI : 10.1007/s11340-015-9996-1
