Simulation of multiple blunt-body flows with a hybrid variational multiscale model - Archive ouverte HAL Access content directly
Conference Papers Year : 2015
The present investigation is motivated by the simulation of high-Reynolds number massively separated flows, a challenging problem of prime interest in industry. The turbulence model is based on a hybridization strategy which blends a vari-ational multiscale large-eddy simulation (VMS-LES) equipped with dynamic subgrid scale (SGS) models and a two-equation RANS model. The dynamic procedure (Germano) allows the adaptation of the constant of the SGS model to the spatial and temporal variation of the flow characteristics, while the VMS formulation restricts the SGS model effects to the smallest resolved scales [1]. The hybridization strategy uses a blending parameter, such that a VMS-LES simulation is applied in region where the grid resolution is fine enough to resolve a significant part of the turbulence fluctuations, while a RANS model is acting in the regions of coarse grid resolution [2]. The capability of the proposed hybrid model to accurately predict the aerodynamic forces acting on a circular cylinder in the supercritical regime and on tandem cylinders are investigated.
Papier-CMFF-2015.pdf (1.56 Mo) Télécharger le fichier
Dates and versions
hal-01256084 , version 1 (14-01-2016)
Identifiers
  • HAL Id : hal-01256084 , version 1
Cite
Emmanuelle Itam, Stephen Wornom, Bruno Koobus, Bruno Sainte-Rose, Alain Dervieux. Simulation of multiple blunt-body flows with a hybrid variational multiscale model. CMFF 2015 - 16th International Conference on Modelling Fluid Flow Technologies, Sep 2015, Budapest, Hungary. pp.1-8. ⟨hal-01256084⟩
214 View
120 Download
Share
