Impact of dynamic subgrid-scale modeling in variational multiscale large-eddy simulation of bluff-body flows, Acta Mechanica, vol.25, issue.2, pp.1-15, 2014. ,
DOI : 10.1007/s00707-014-1112-6
Simulation of the flow past a circular cylinder in the supercritical regime by blending RANS and variational-multiscale LES models, Journal of Fluids and Structures, vol.47, pp.114-123, 2014. ,
DOI : 10.1016/j.jfluidstructs.2013.11.006
URL : https://hal.archives-ouvertes.fr/hal-01083801
Comments on the feasibility of LES for wings, and on a hybrid RANS/LES approach, Advances in DNS/LES, pp.137-147, 1997. ,
A New Version of Detached-eddy Simulation, Resistant to Ambiguous Grid Densities, Theoretical and Computational Fluid Dynamics, vol.140, issue.3, pp.181-195, 2006. ,
DOI : 10.1007/s00162-006-0015-0
Approximate Riemann solvers, parameter vectors, and difference schemes, Journal of Computational Physics, vol.43, issue.2, pp.357-372, 1981. ,
DOI : 10.1016/0021-9991(81)90128-5
Towards the ultimate conservative difference scheme. IV. A new approach to numerical convection, Journal of Computational Physics, vol.23, issue.3, pp.276-299, 1977. ,
DOI : 10.1016/0021-9991(77)90095-X
A low-diffusion MUSCL scheme for LES on unstructured grids, Computers & Fluids, vol.33, issue.9, pp.1101-1129, 2004. ,
DOI : 10.1016/j.compfluid.2003.10.002
URL : https://hal.archives-ouvertes.fr/hal-00372840
Large Eddy Simulation and the variational multiscale method, Computing and Visualization in Science, vol.3, issue.1-2, pp.47-59, 2000. ,
DOI : 10.1007/s007910050051
A variational multiscale method for the large eddy simulation of compressible turbulent flows on unstructured meshes??????application to vortex shedding, Computer Methods in Applied Mechanics and Engineering, vol.193, issue.15-16, pp.1367-1383, 2004. ,
DOI : 10.1016/j.cma.2003.12.028
URL : https://hal.archives-ouvertes.fr/hal-00372839
Subgridscale stress modelling based on the square of the velocity gradient tensor, Flow, Turbulence and Combustion, vol.62, issue.3, pp.183-200, 1999. ,
DOI : 10.1023/A:1009995426001
URL : https://hal.archives-ouvertes.fr/hal-00910373
A dynamic subgrid???scale eddy viscosity model, Physics of Fluids A: Fluid Dynamics, vol.3, issue.7, pp.1760-1765, 1991. ,
DOI : 10.1063/1.857955
A proposed modification of the Germano subgrid???scale closure method, Physics of Fluids A: Fluid Dynamics, vol.4, issue.3, p.633, 1992. ,
DOI : 10.1063/1.858280
A k-epsilon near-wall formulation for separated flows, 21st Fluid Dynamics, Plasma Dynamics and Lasers Conference, 1990. ,
DOI : 10.2514/6.1990-1482
A dynamical subgrid-scale eddy viscosity model with a global model coefficient, Phys Fluids, vol.18, issue.12, 2006. ,
Numerical studies of flow over a circular cylinder at ReD=3900, Physics of Fluids, vol.12, issue.2, pp.403-417, 1999. ,
DOI : 10.1063/1.870318
Experimental and numerical studies of the flow over a circular cylinder at Reynolds number 3900, Physics of Fluids, vol.20, issue.8, 2008. ,
DOI : 10.1063/1.2957018
Effects of Reynolds number and low-intensity free-sream turbulence on the flow around a circular cylinder, Publ No, vol.872, 1987. ,
The velocity field of the turbulent very near wake of a circular cylinder, Experiments in Fluids, vol.20, issue.6, pp.441-453, 1996. ,
DOI : 10.1007/BF00189383
Status of Large Eddy Simulation: Results of a Workshop, Journal of Fluids Engineering, vol.119, issue.2, pp.248-262, 1997. ,
DOI : 10.1115/1.2819128
Prediction of high Reynolds number the flow over a circular cylinder using LES, Annual research briefs, 2001. ,
Prediction of Unsteady Loading on a Circular Cylinder in High Reynolds Number Flows Using Large Eddy Simulation, 24th International Conference on Offshore Mechanics and Arctic Engineering: Volume 3, pp.12-16, 2005. ,
DOI : 10.1115/OMAE2005-67044
Experiments on flow past rough circular cylinders at large Reynolds numbers, Journal of Wind Engineering and Industrial Aerodynamics, vol.49, issue.1-3, pp.351-368, 1993. ,
DOI : 10.1016/0167-6105(93)90030-R
Experimental investigations of separating boundary-layer flow from circular cylinder at Reynolds numbers from 10 5 up to 10 7 ; Three-dimensional vortex flow of a circular cylinder The Netherlands, Proceedings of IUTAM Symposium on One Hundred Years of Bloundary Layer Research, pp.455-462, 2006. ,
Summary of the Tandem Cylinder Solutions from the Benchmark problems for Airframe Noise Computations-I Workshop, 49th AIAA Aerospace Sciences Meeting including the New Horizons Forum and Aerospace Exposition, pp.2011-353, 2011. ,
DOI : 10.2514/6.2011-353
Assessment of Hybrid RANS/LES turbulence models for areoacoustics applications, AIAA Paper, pp.2010-4001, 2010. ,
Measurements of the Flowfield Interaction Between Tandem Cylinders, 15th AIAA/CEAS Aeroacoustics Conference (30th AIAA Aeroacoustics Conference), pp.2009-3275, 2009. ,
DOI : 10.2514/6.2009-3275
