Aérodynamique instationnaire et méthode adjointe, 2011. ,
Time accurate anisotropic goal-oriented mesh adaptation for unsteady flows, J. Comp. Phys, vol.231, issue.19, pp.6323-6348, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00940095
A panoramic view of Riemannian geometry, 2003. ,
A mesh-adaptive metric-based Full-Multigrid for the Poisson problem. submitted to I, J. Numer. Meth. Fluids, 2014. ,
Adjoint Error Correction for Integral Outputs, Lecture Notes in Computational Science and Engineering, vol.25, pp.47-96, 2002. ,
Continuous mesh framework. Part I: well-posed continuous interpolation error, SIAM Journal on Numerical Analysis, vol.49, issue.1, pp.38-60, 2011. ,
Continuous mesh framework. Part II: validations and applications, SIAM Journal on Numerical Analysis, vol.49, issue.1, pp.61-86, 2011. ,
Fully anisotropic goal-oriented mesh adaptation for 3D steady Euler equations, J. Comp. Phys, vol.229, issue.8, pp.2866-2897, 2010. ,
Achievement of global secondorder mesh convergence for discontinuous flows with adapted unstructured meshes, 37th AIAA Fluid Dynamics Conference and Exhibit, 2007. ,
Serial and parallel mesh modification through a unique cavity-based primitive, Proceedings of the 22th International Meshing Roundtable, pp.541-558, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00935356
, Computational Fluid Dynamics, 2011.
URL : https://hal.archives-ouvertes.fr/hal-00623255
Perspective: a method for uniform reporting of grid refinement studies, Journal of Fluid Engineering, vol.116, pp.405-413, 1994. ,
