Wolf user guide An edge-based Navier-Stokes flow solver based on the MEV numerical scheme, 2010. ,
High-order sonic boom modeling based on adaptive methods, Journal of Computational Physics, vol.229, issue.3, pp.561-593, 2010. ,
DOI : 10.1016/j.jcp.2009.09.020
Average-state Jacobians and implicit methods for compressible viscous and turbulent flows Time accurate anisotropic goal-oriented mesh adaptation for unsteady flows Anisotropic mesh adaption by metric-driven optimization Advances in numerical methods for CREATE-AV analysis tools, M. J. Castro-Díaz, F. Hecht, B. Mohammadi, and O. Pironneau. Anisotropic unstructured mesh adaptation for flow simulations, pp.38-786323, 1997. ,
Optimal anisotropic meshes for minimizing interpolation errors in L p -norm A mesh adaptation framework for dealing with large deforming meshes, Math. Comp. Int. J, vol.25, issue.76257 9, pp.475-491179, 1997. ,
Génération de maillages et adaptation de maillage par optimisation locale, Cournède, B. Koobus, and A. Dervieux. Positivity statements for a Mixed-Element-Volume scheme on fixed and moving grids, pp.843-867403, 2000. ,
Anisotropic delaunay mesh adaptation for unsteady simulations Anisotropic mesh adaptation: towards a solver and user independent CFD AIAA-1997-0861 Anisotropic mesh adaptation for CFD computations Mesh generation. Application to finite elements Gamanic3d, adaptive anisotropic tetrahedral mesh generator Technical Note, INRIA On adjoint equations for error analysis and optimal grid adaptation in CFD Improved lift and drag estimates using adjoint euler equations AIAA Paper Adjoint methods for PDEs: a posteriori error analysis and postprocessing by duality Metric tensors for anisotropic mesh generation Validation of 3D adjoint based error estimation and mesh adaptation for sonic boom reduction 3D anisotropic mesh adaptation by mesh modification 24 A. Loseille. Adaptation de maillage 3D anisotrope multi-´ echelles et cibléciblé`cibléà une fonctionnelle. ApplicationàApplication`Applicationà la prédiction haute-fidélité du bang sonique 25 A. Loseille and F. Alauzet. Continuous mesh framework. Part I: well-posed continuous interpolation error Achievement of global second-order mesh convergence for discontinuous flows with adapted unstructured meshes Adaptive anisotropic simulations in aerodynamics, European Journal of Computational Mechanics Proceedings of WEHSFF Proc. of 17th Int. Meshing Rountable AIAA 35th Aerospace Sciences Meeting and Exhibit Acta Numerica 44th AIAA Aerospace Sciences Meeting and Exhibit, AIAA-2006-1150 26 A. Loseille and F. Alauzet. Continuous mesh framework. Part II: validations and applications 27 A. Loseille, A. Dervieux, and F. Alauzet. Fully anisotropic goal-oriented mesh adaptation for 3D steady Euler equations. J. Comp. Phys. 37th AIAA Fluid Dynamics Conference 48th AIAA Aerospace Sciences Meeting, pp.767-798, 1930. ,
Serial and parallel mesh modification through a unique cavity-based primitive A fast, matrix-free implicit method for compressible flows on unstructured grids, Proceedings of the 22nd International Meshing Roundtable 32 H. Luo, J.D. Baum, and R. Löhner. An accurate, fast, matrix-free implicit method for computing unsteady flows on unstructured grids, pp.664-690, 1998. ,
34 K. Mer. Variational analysis of a mixed element/volume scheme with fourth-order viscosity on general triangulations Tetrahedral mesh optimisation and adaptivity for steady-state and transient finite element calculations Adjoint a posteriori error measures for anisotropic mesh optimization Implementation of unstructured grid GMRES+LU-SGS method on shared-memory, cachebased parallel computers Anisotropic mesh adaptation for 3D flows on structured and unstructured grids Grid adaptation for functional outputs: application to two-dimensional inviscid flows, 44th AIAA Fluid Dynamics Conference 39 Y.V. Vasilevski and K.N. Lipnikov. Error bounds for controllable adaptive algorithms based on a hessian recovery. Computational Mathematics and Mathematical Physics, pp.137-15945, 1998. ,
