Conference papers
A low Mach correction for the Godunov scheme applied to the linear wave equation with porosity
Abstract : We study the low Mach number behavior of the Godunov finite volume scheme applied to the linear wave equation with porosity. More precisely, we extend the Hodge decomposition to a weighted L2 space. We illustrate the influence of the cell geometry on the accuracy property at low Mach number. In the triangular case, the stationary space of the Godunov scheme approaches well enough the continuous space of constant pressure and divergent-free velocity while this is not the case in the Cartesian case. We study the properties of the modified equation associated to this Godunov scheme and we propose some correction that is continuous with respect to the Mach number.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01256455
Contributor : Jonathan Jung Connect in order to contact the contributor
Submitted on : Thursday, January 14, 2016 - 6:35:15 PM
Last modification on : Thursday, January 20, 2022 - 5:29:36 PM
Identifiers
  • HAL Id : hal-01256455, version 1
Collections
Citation
Jonathan Jung. A low Mach correction for the Godunov scheme applied to the linear wave equation with porosity. Low velocity flows, Nov 2015, Paris, France. ⟨hal-01256455⟩
Share
Metrics
Record views
147
