An Algebraic View of Space/Belief and Extrusion/Utterance for Concurrency/Epistemic Logic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We enrich spatial constraint systems with operators to specify information and processes moving from a space to another. We shall refer to these news structures as spatial constraint systems with extrusion. We shall investigate the properties of this new family of constraint systems and illustrate their applications. From a computational point of view the new operators provide for pro-cess/information extrusion, a central concept in formalisms for mobile communication. From an epistemic point of view extrusion corresponds to a notion we shall call utterance; a piece of information that an agent communicates to others but that may be inconsistent with the agent's beliefs. Utterances can then be used to express instances of epistemic notions, which are common place in social media, such as hoaxes or intentional lies. Spatial constraint systems with extrusion can be seen as complete Heyting algebras equipped with maps to account for spatial and epistemic specifications
mccp-ppdp-author-copy.pdf (320.25 Ko) Télécharger le fichier
hal-01256984 , version 1 (20-01-2016)
Stefan Haar, Salim Perchy, Camilo Rueda, Frank Valencia. An Algebraic View of Space/Belief and Extrusion/Utterance for Concurrency/Epistemic Logic. 17th International Symposium on Principles and Practice of Declarative Programming (PPDP 2015), Jul 2015, Siena, Italy. pp.161-172, ⟨10.1145/2790449.2790520⟩. ⟨hal-01256984⟩
600 Consultations
388 Téléchargements
