Continuous-Discrete Observers for Time-Varying Nonlinear Systems: A Tutorial on Recent Results - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Continuous-discrete systems can occur when the plant state evolves in continuous time but the output values are only available at discrete instants. Continuous-discrete observers have the valuable property that the observation error between the true state of the system and the observer state converges to zero in a uniform way. The design of continuous-discrete observers can often be done by building framers, which provide componentwise upper and lower bounds for the plant state. This paper is a tutorial on these approaches, highlighting recent results in the literature, and also providing previously unpublished, original results which are not being simultaneously submitted elsewhere.
Automatique
8April2015CT15.pdf (307.96 Ko) Télécharger le fichier
hal-01257347 , version 1 (16-01-2016)
Frederic Mazenc, Vincent Andrieu, Michael Malisoff. Continuous-Discrete Observers for Time-Varying Nonlinear Systems: A Tutorial on Recent Results. 2015 SIAM Conference on Control and its Applications , Jul 2015, Paris, France. ⟨10.1137/1.9781611974072.26⟩. ⟨hal-01257347⟩
345 Consultations
173 Téléchargements
