Abstract : The Clock Constraint Specification Language (CCSL) has initially been introduced as part of the UML Profile for Marte dedicated to the modeling and analysis of real-time and embedded systems. CCSL proposes a set of simple patterns classically used to specify causal and temporal properties of (UML/EMF) models. The paper proposes a new semantic model for CCSL based on the notion of “clock coalgebra”. Coalgebra promises to give a unified framework to study the behavior and semantics of reactive systems and, more generally, infinite data structures. They appear as being the adequate mathematical structure to capture the infinite nature of CCSL operators. This paper proposes a coalgebraic structure for CCSL, or rather a natural generalization of CCSL that we call generalized clock constraints: GenCCSL. We establish that GenCCSL covers the class of CCSL constraints and we give examples of GenCCSL constraints that cannot be expressed with classical CCSL. Then, we discuss the properties of the newly introduced class, including ways to detect valid and invalid GenCCSL behaviors, as well as deciding whether a GenCCSL constraint is also a CCSL one.
