J. Albus, R. Bostelman, and N. Dagalakis, The NIST SPIDER, A robot crane, Journal of Research of the National Institute of Standards and Technology, vol.97, issue.3, pp.373-385, 1992.
DOI : 10.6028/jres.097.016
S. E. Landsberger and T. B. Sheridan, A new design for parallel link manipulator, Proc. Systems, Man and Cybernetics Conf, pp.812-814, 1985.
T. Bruckman, Parallel manipulators, New Developments, chapter Wire robot part I, kinematics, analysis and design, pp.109-132, 2008.
Q. Jiang and V. Kumar, The Inverse Kinematics of 3-D Towing, ARK, pp.321-328, 2010.
DOI : 10.1007/978-90-481-9262-5_34
R. G. Roberts, T. Graham, and T. Lippit, On the inverse kinematics, statics, and fault tolerance of cable-suspended robots, Journal of Robotic Systems, vol.15, issue.10, pp.581-597, 1998.
DOI : 10.1002/(SICI)1097-4563(199810)15:10<581::AID-ROB4>3.0.CO;2-P
R. Verhoeven, Analysis of the workspace of tendon-based Stewart platforms, 2004.
G. Abbasnejad and M. Carricato, Real solutions of the direct geometrico-static problem of underconstrained cable-driven parallel robot with 3 cables: a numerical investigation, Meccanica, issue.7, pp.4731761-1773, 2012.
A. Berti, J. Merlet, and M. Carricato, Solving the Direct Geometrico-Static Problem of 3-3 Cable-Driven Parallel Robots by Interval Analysis: Preliminary Results, 1st Int. Conf. on cable-driven parallel robots (CableCon), pp.251-268, 2012.
DOI : 10.1007/978-3-642-31988-4_16
M. Carricato and J. Merlet, Direct geometrico-static problem of under-constrained cable-driven parallel robots with three cables, 2011 IEEE International Conference on Robotics and Automation, pp.3011-3017, 2011.
DOI : 10.1109/ICRA.2011.5979762
M. Carricato and G. Abbasnejad, Direct Geometrico-Static Analysis of Under-Constrained Cable-Driven Parallel Robots with 4 Cables, 1st Int. Conf. on cable-driven parallel robots (CableCon), pp.269-286, 2012.
DOI : 10.1007/978-3-642-31988-4_17
A. Pott, An algorithm for real-time forward kinematics of cabledriven parallel robots, ARK, pp.529-538, 2010.
M. Carricato and J. Merlet, Stability Analysis of Underconstrained Cable-Driven Parallel Robots, IEEE Transactions on Robotics, vol.29, issue.1, pp.288-296, 2013.
DOI : 10.1109/TRO.2012.2217795
URL : https://hal.archives-ouvertes.fr/hal-01425222
A. Pott, IPAnema: a family of cable-driven parallel robots for industrial applications, 1st Int. Conf. on cable-driven parallel robots (CableCon), pp.119-134, 2012.
S. Tadokoro, A portable parallel manipulator for search and rescue at large-scale urban earthquakes and an identification algorithm for the installation in unstructured environments, Proceedings 1999 IEEE/RSJ International Conference on Intelligent Robots and Systems. Human and Environment Friendly Robots with High Intelligence and Emotional Quotients (Cat. No.99CH36289), pp.1222-1227, 1999.
DOI : 10.1109/IROS.1999.812846
J. Merlet and D. Daney, A portable, modular parallel wire crane for rescue operations, 2010 IEEE International Conference on Robotics and Automation, pp.2834-2839, 2010.
DOI : 10.1109/ROBOT.2010.5509299
URL : https://hal.archives-ouvertes.fr/hal-00987462
Y. X. Su, Development of a large parallel-cable manipulator for the feed-supporting system of a next-generation large radio telescope, Journal of Robotic Systems, vol.10, issue.11, pp.633-643, 2001.
DOI : 10.1002/rob.8102
M. Harshe, J. Merlet, D. Daney, and S. Bennour, A multi-sensors system for human motion measurement: Preliminary setup, 13th IFToMM World Congress on the Theory of Machines and Mechanisms, 2011.
URL : https://hal.archives-ouvertes.fr/hal-00987453
G. Rosati, P. Gallina, and S. Masiero, Design, Implementation and Clinical Tests of a Wire-Based Robot for Neurorehabilitation, IEEE Transactions on Neural Systems and Rehabilitation Engineering, vol.15, issue.4, pp.560-569, 2007.
DOI : 10.1109/TNSRE.2007.908560
J. Merlet, MARIONET, A Family of Modular Wire-Driven Parallel Robots, ARK, pp.53-62, 2010.
DOI : 10.1007/978-90-481-9262-5_6
T. Dallej, N. Andreff, and P. Martinet, Towards a generic imagebased visual servoing of parallel robots using legs observation, 12th IFToMM World Congress on the Theory of Machines and Mechanisms, 2007.
J. Merlet, Solving the Forward Kinematics of a Gough-Type Parallel Manipulator with Interval Analysis, The International Journal of Robotics Research, vol.23, issue.3, pp.221-236, 2004.
DOI : 10.1177/0278364904039806
J. Merlet, The Forward Kinematics of Cable-Driven Parallel Robots with Sagging Cables, 2nd Int. Conf. on cable-driven parallel robots (CableCon), pp.3-16, 2014.
DOI : 10.1007/978-3-319-09489-2_1
URL : https://hal.archives-ouvertes.fr/hal-01425215
E. Hansen, AN OVERVIEW OF GLOBAL OPTIMIZATION USING INTERVAL ANALYSIS, 2004.
DOI : 10.1016/B978-0-12-505630-4.50021-3
L. Jaulin, M. Kieffer, O. Didrit, and E. Walter, Applied Interval Analysis, 2001.
DOI : 10.1007/978-1-4471-0249-6
URL : https://hal.archives-ouvertes.fr/hal-00845131
R. E. Moore, Methods and Applications of Interval Analysis, SIAM Studies in Applied Mathematics, 1979.
DOI : 10.1137/1.9781611970906
A. Neumaier, Interval methods for systems of equations, 1990.
DOI : 10.1017/CBO9780511526473
O. Knppel, PROFIL/BIAS???Eine schnelle Intervallbibliothek, Computing, vol.5, issue.3-4, pp.277-287, 1994.
DOI : 10.1007/BF02307379
J. Merlet, ALIAS: an interval analysis based library for solving and analyzing system of equations, pp.14-16, 2000.
F. Laurent, H. Guillaume, L. Vincent, P. Patrick, and Z. Paul, Mpfr: A multiple-precision binary floating-point library with correct rounding, ACM Trans. Math. Softw, vol.33, issue.2, 2007.
M. Gouttefarde, Simplified static analysis of largedimension parallel cable-driven robots, IEEE Int. Conf. on Robotics and Automation, pp.2299-2305, 2012.
URL : https://hal.archives-ouvertes.fr/lirmm-00737544
P. Miermeister, An Elastic Cable Model for Cable-Driven Parallel Robots Including Hysteresis Effects, 2nd Int. Conf. on cabledriven parallel robots (CableCon), pp.17-28, 2014.
DOI : 10.1007/978-3-319-09489-2_2
T. Bruckmann, A. Pott, and M. Hiller, Calculating force distributions for redundantly actuated tendon-based Stewart platforms, ARK, pp.403-412, 2006.
DOI : 10.1007/978-1-4020-4941-5_44
X. Diao and O. Ma, Force-closure analysis of 6-DOF cable manipulators with seven or more cables, Robotica, vol.111, issue.02, pp.209-215, 2009.
DOI : 10.1115/1.2121748
M. Hassan and A. Khajepour, Minimum-norm Solution for the Actuator Forces in Cable-based Parallel Manipulators based on Convex Optimization, Proceedings 2007 IEEE International Conference on Robotics and Automation, pp.1498-1503, 2007.
DOI : 10.1109/ROBOT.2007.363196
J. Lamaury, Design and Control of a Redundant Suspended Cable-Driven Parallel Robots, ARK, pp.237-244, 2012.
DOI : 10.1007/978-94-007-4620-6_30
URL : https://hal.archives-ouvertes.fr/lirmm-00737551
L. Blanchet and J. Merlet, Interference detection for cable-driven parallel robots (CDPRs), 2014 IEEE/ASME International Conference on Advanced Intelligent Mechatronics, pp.1413-1418, 2014.
DOI : 10.1109/AIM.2014.6878280
URL : https://hal.archives-ouvertes.fr/hal-01095093
J. Merlet, Analysis of the Influence of Wires Interference on the Workspace of Wire Robots, ARK, pp.211-218, 2004.
DOI : 10.1007/978-1-4020-2249-4_23
Y. Wischnitzer, N. Shvalb, and M. Shoham, Wire-driven Parallel Robot: Permitting Collisions Between Wires, The International Journal of Robotics Research, vol.3, issue.2, pp.1007-1026, 2008.
DOI : 10.1177/0278364908095884
