Conference papers
Évaluation de la pertinence dans les moteurs de recherche géoréférencés
Abstract : Learning to rank documents on a search engine requires relevance judgments. We introduce the results of an innovating study on relevance modeling for local search engines. These search engines present search results on a map or as a list of maps. Each map contains all the attributes of a place (noun, address, phone number, etc). Most of these attributes are links users can click. We model the relevance as the weighted sum of all the clicks on a result. We obtain good results by fixing the same weight for each component of the model. We propose a relative order between clicks to determine the optimal weights.
Document type :
Conference papers
Complete list of metadata
Cited literature [19 references]  Display  Hide  Download
https://hal.inria.fr/hal-01259542
Contributor : Léa LAPORTE Connect in order to contact the contributor
Submitted on : Wednesday, January 20, 2016 - 3:45:18 PM
Last modification on : Monday, July 4, 2022 - 8:59:15 AM
Long-term archiving on: : Friday, November 11, 2016 - 1:31:40 PM
File
2012_INFORSID_LL_LC_SD_JM.pdf
Identifiers
  • HAL Id : hal-01259542, version 1
Citation
Léa Laporte, Laurent Candillier, Sébastien Dejean, Josiane Mothe. Évaluation de la pertinence dans les moteurs de recherche géoréférencés. INFormatique des Organisations et Systemes d'Information et de Decision (INFORSID 2012), May 2012, Montpellier, France. pp.16. ⟨hal-01259542⟩
Share
Metrics
Record views
91
Files downloads
81
