Analysis of an optimal control problem for the tridomain model in cardiac electrophysiology, Journal of Mathematical Analysis and Applications, vol.388, issue.1, pp.231-247, 2012. ,
DOI : 10.1016/j.jmaa.2011.11.069
Convergence of discrete duality finite volume schemes for the cardiac bidomain model. Networks and Heterogeneous Media, pp.195-240, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00526047
Solvability analysis and numerical approximation of linearized cardiac electromechanics, Mathematical Models and Methods in Applied Sciences, vol.25, issue.05, pp.25959-993, 2015. ,
DOI : 10.1142/S0218202515500244
URL : https://hal.archives-ouvertes.fr/hal-01256811
A generic grid interface for parallel and adaptive scientific computing. Part II: implementation and tests in DUNE, Computing, vol.24, issue.1, pp.121-138, 2008. ,
DOI : 10.1007/s00607-008-0004-9
Analysis of a class of degenerate reaction-diffusion systems and the bidomain model of cardiac tissue. Networks and Heterogeneous Media, pp.185-218, 2006. ,
A parallel algebraic multigrid method for elliptic problems with highly discontinuous coefficients, 2010. ,
Existence and uniqueness of the solution for the bidomain model used in cardiac electrophysiology, Nonlinear Analysis: Real World Applications, vol.10, issue.1, pp.458-482, 2009. ,
DOI : 10.1016/j.nonrwa.2007.10.007
URL : https://hal.archives-ouvertes.fr/hal-00101458
Theoretical analysis and control results for the fitzhugh-nagumo equation, Electronic Journal of Differential Equations (EJDE), issue.164, 2008. ,
Analyse fonctionnelle, théorie et applications, 1983. ,
Sparse optimal control of the schlögl and fitzhugh-nagumo systems, Comput. Meth. in Appl. Math, vol.13, issue.4, pp.415-442, 2013. ,
Primal-dual active set strategy for large scale optimization of cardiac defibrillation. submitted, 2015. ,
Numerical solution for optimal control of the reaction-diffusion equations in cardiac electrophysiology, Computational Optimization and Applications, vol.49, pp.149-178 ,
Optimal control approach to termination of re-entry waves in cardiac electrophysiology, Journal of Mathematical Biology, pp.1-30 ,
PDE constrained optimization of electrical defibrillation in a 3D ventricular slice geometry, International Journal for Numerical Methods in Biomedical Engineering, vol.59, issue.8, 2015. ,
DOI : 10.1007/s10589-009-9280-3
Impulses and Physiological States in Theoretical Models of Nerve Membrane, Biophysical Journal, vol.1, issue.6, pp.445-466, 1961. ,
DOI : 10.1016/S0006-3495(61)86902-6
Degenerate Evolution Systems Modeling the Cardiac Electric Field at Micro- and Macroscopic Level, pp.49-78, 2006. ,
DOI : 10.1007/978-3-0348-8221-7_4
Simulating the electrical behavior of cardiac tissue using the bidomain model, Crit. Rev. Biomed. Eng, vol.21, pp.1-77, 1993. ,
Cardiac Microstructure: Implications for Electrical Propagation and Defibrillation in the Heart, Circulation Research, vol.91, issue.4, pp.331-338, 2002. ,
DOI : 10.1161/01.RES.0000031957.70034.89
Results on the nature of the continuity of solutions of parabolic equations, and certain applications thereof, Mat. Zametki, vol.6, pp.97-108, 1969. ,
Optimal control of the bidomain system (III): Existence of minimizers and first-order optimality conditions, ESAIM: Mathematical Modelling and Numerical Analysis, vol.47, issue.4, pp.1077-1106, 2013. ,
DOI : 10.1051/m2an/2012058
A two-current model for the dynamics of cardiac membrane, Bulletin of Mathematical Biology, vol.65, issue.5, pp.767-793, 2003. ,
DOI : 10.1016/S0092-8240(03)00041-7
Bioelectric sources arising in excitable fibers (Alza lecture), Annals of Biomedical Engineering, vol.125, issue.6, pp.519-565, 1988. ,
DOI : 10.1007/BF02368014
Electrical conductivity values used with the bidomain model of cardiac tissue, IEEE Transactions on Biomedical Engineering, vol.44, issue.4, pp.326-328, 1997. ,
DOI : 10.1109/10.563303
A bi-domain model for describing ischemic myocardial DC potentials, 1978. ,
Reaction???diffusion systems for the macroscopic bidomain model of the cardiac electric field, Nonlinear Analysis: Real World Applications, vol.10, issue.2, pp.849-868, 2009. ,
DOI : 10.1016/j.nonrwa.2007.11.008
