Teaching a new trick to an old dog: Revisiting the quadratic programming formulation of sparse recovery using admm, Acoustics, Speech and Signal Processing (ICASSP), 2014 IEEE International Conference on, pp.1512-1516, 2014. ,
A mathematical introduction to compressive sensing., Applied and Numerical Harmonic Analysis, 2013. ,
A new approach to variable selection in least squares problems, IMA Journal of Numerical Analysis, vol.20, issue.3, pp.389-403, 2000. ,
DOI : 10.1093/imanum/20.3.389
Least angle regression, The Annals of Statistics, vol.32, issue.2, pp.407-451, 2004. ,
A Fast Iterative Shrinkage-Thresholding Algorithm for Linear Inverse Problems, SIAM Journal on Imaging Sciences, vol.2, issue.1, pp.183-202, 2009. ,
DOI : 10.1137/080716542
Fast Image Recovery Using Variable Splitting and Constrained Optimization, IEEE Transactions on Image Processing, vol.19, issue.9, pp.2345-2356, 2010. ,
DOI : 10.1109/TIP.2010.2047910
URL : http://arxiv.org/abs/0910.4887
Safe feature elimination in sparse supervised learning, 2010. ,
Lasso screening with a small regularization parameter, 2013 IEEE International Conference on Acoustics, Speech and Signal Processing, pp.3342-3346, 2013. ,
DOI : 10.1109/ICASSP.2013.6638277
Learning sparse representations of high dimensional data on large scale dictionaries, Advances in Neural Information Processing Systems 24, J. Shawe-taylor, pp.900-908, 2011. ,
Fast lasso screening tests based on correlations, Acoustics, Speech and Signal Processing (ICASSP), 2012 IEEE International Conference on, pp.2137-2140, 2012. ,
The 2-codeword screening test for lasso problems, 2013 IEEE International Conference on Acoustics, Speech and Signal Processing, pp.3307-3311, 2013. ,
DOI : 10.1109/ICASSP.2013.6638270
Screening tests for lasso problems, 2014. ,
Safe screening with variational inequalities and its application to lasso, Proceedings of the 31st International Conference on Machine Learning (ICML-14) Conference Proceedings, pp.289-297, 2014. ,
Lasso screening rules via dual polytope projection, Journal of Machine Learning Research, 2015. ,
Mind the duality gap: safer rules for the lasso, ICML, 2015. ,
The lasso problem and uniqueness, Electronic Journal of Statistics, vol.7, pp.1456-1490, 2013. ,
A dynamic screening principle for the lasso, Signal Processing Conference (EUSIPCO), 2014 Proceedings of the 22nd European, pp.6-10, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00880787
Dynamic Screening: Accelerating First-Order Algorithms for the Lasso and Group-Lasso, IEEE Transactions on Signal Processing, vol.63, issue.19, pp.5121-5132, 2015. ,
DOI : 10.1109/TSP.2015.2447503
URL : https://hal.archives-ouvertes.fr/hal-01084986
