Adaptive Observer for a Class of Parabolic PDEs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2016
The problem of state observation, based on spatially-sampled output measurements, is addressed for a class of infinite dimensional systems, modelled by a semi-linear heat equation augmented with a structured uncertain part involving a set of unknown parameters. An adaptive observer is designed that provides online estimates of the system (spatially distributed) state and unknown parameters based on sampled data (in space). Sufficient conditions for the observer to be exponentially convergent are established. These include an ad-hoc persistent excitation condition as well as a condition on how the observer gain must be selected in relation with the space sampling interval.
TAA2016.pdf (176.71 Ko) Télécharger le fichier
hal-01260172 , version 1 (18-05-2022)
Paternité - Pas d'utilisation commerciale
Tarek Ahmed-Ali, Fouad Giri, Miroslav Krstic, Françoise Lamnabhi-Lagarrigue, Laurent Burlion. Adaptive Observer for a Class of Parabolic PDEs. IEEE Transactions on Automatic Control, 2016, 61 (10), pp.3083-3090. ⟨10.1109/tac.2015.2500237⟩. ⟨hal-01260172⟩
322 Consultations
71 Téléchargements
