Robust Stabilization of Nonlinear Globally Lipschitz Delay Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2016
This paper studies the application of a recently proposed control scheme to globally Lipschitz nonlinear systems for which the input is delayed and applied with zero order hold, the measurements are sampled and delayed, and only an output is measured (i.e., the state vector is not available). The control scheme consists of an observer for the delayed state vector, an inter-sample predictor for the output signal, an approximate predictor for the future value of the state vector, and the nominal feedback law applied with zero order hold and computed for the predicted value of the future state vector. The resulting closed-loop system is robust with respect to modeling and measurement errors and robust to perturbations of the sampling schedule.
Ahmed-Ali2016.pdf (157.58 Ko) Télécharger le fichier
hal-01260378 , version 1 (18-05-2022)
Paternité - Pas d'utilisation commerciale
Tarek Ahmed-Ali, I. Karafyllis, M. Krstic, Françoise Lamnabhi-Lagarrigue. Robust Stabilization of Nonlinear Globally Lipschitz Delay Systems. Iasson Karafyllis; Michael Malisoff; Frédéric Mazenc; Pierdomenico Pepe. Recent Results on Nonlinear Delay Control Systems, Springer Verlag, pp.43-60, 2016, Advances in Delays and Dynamics, 978-3-319-36760-6. ⟨10.1007/978-3-319-18072-4_2⟩. ⟨hal-01260378⟩
144 Consultations
40 Téléchargements
