Abstract : At HSG-IMAT the precision assembly of micro systems became increasingly important in recent years. The challenge is to reach a high accuracy of about 10 μm between the assembled elements. At the same time it is important that the applied processes are suitable for low cost manufacturing. Attempts were made to achieve these requirements by means of automatic assembly processes based on MID and PCB. The results of the development at HSG-IMAT are shown in this contribution using the example of an optical module of a rotary encoder. Thereby, the assembly of the laser diode and lens requires special attention to achieve the specified positioning tolerances.
https://hal.inria.fr/hal-01260723 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, January 22, 2016 - 3:03:26 PM Last modification on : Tuesday, May 3, 2016 - 5:03:59 PM Long-term archiving on: : Saturday, April 23, 2016 - 10:55:57 AM
Jonathan Seybold, Ulrich Kessler, Karl-Peter Fritz, Heinz Kück. Precision Micro Assembly of Optical Components on MID and PCB. 7th International Precision Assembly Seminar (IPAS), Feb 2014, Chamonix, France. pp.30-36, ⟨10.1007/978-3-662-45586-9_5⟩. ⟨hal-01260723⟩
