Abstract : This paper describes the dynamics of capillary self-alignment of components with initial shift offsets from matching receptor sites. The analysis of the full uniaxial self-alignment dynamics of foil-based mesoscopic dies from pre-alignment to final settling evidenced three distinct, sequential regimes impacting the process performance. The dependence of accuracy, alignment time and repeatability of capillary self-alignment on control parameters such as size, weight, surface energy and initial offset of assembling dies was investigated. Finally, we studied the influence of the dynamic coupling between the degenerate oscillation modes of the system on the alignment performance by means of pre-defined biaxial offsets.
https://hal.inria.fr/hal-01260862 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, January 22, 2016 - 4:07:31 PM Last modification on : Friday, November 19, 2021 - 12:42:03 PM Long-term archiving on: : Saturday, April 23, 2016 - 11:05:21 AM
Gari Arutinov, Mastrangeli Massimo, Smits C. P. Edsger, van Heck Gert, Shoo F. M. Herman, et al.. Shift Dynamics of Capillary Self-Alignment. 7th International Precision Assembly Seminar (IPAS), Feb 2014, Chamonix, France. pp.61-68, ⟨10.1007/978-3-662-45586-9_9⟩. ⟨hal-01260862⟩
