Leach Ultrasonic Press?Fitting: A New Assembly Technique, p.22 ,
Jacot Precision Micro Assembly of Optical Components on MID and PCB, p.30 ,
Kück Integrated Tool-Chain Concept for Automated Micro-optics Assembly, p.37 ,
Christoph Pallasch, and Christian Brecher Feeding of Small Components Using the Surface Tension of Fluids, p.47 ,
Dirk Schlenker, and Alexander Verl Precision Handling of Electronic Components for PCB Rework, p.52 ,
and Irene Fassi Shift Dynamics of Capillary Self-Alignment, p.61 ,
and Reijo Tuokko Concept of a Virtual Metrology Frame Based on Absolute Interferometry for, p.79 ,
Quinders Application of Deep Belief Networks for Precision Mechanism Quality Inspection ,
and Philipp Glocker Visual Quality Inspection and Fine Anomalies: Methods and Application, p.94 ,
Jochum Control Methods in Microspheres Precision Assembly for Colloidal Lithography ,
118 Nikolas Antzoulatos, Elkin Castro, Daniele Scrimieri, and Svetan Ratchev Process Module Construction Kit for Modular Micro Assembly Systems, p.126 ,
Dirk Schlenker, and Alexander Verl A Generic Systems Engineering Method for Concurrent Development of Products and Manufacturing Equipment, p.139 ,
147 Markus Dickerhof, Pfleging, and Maika Torge Optimal Design of Remote Center Compliance Devices of Rotational Symmetry, p.161 ,
