HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
New Evolutionary Classifier Based on Genetic Algorithms and Neural Networks: Application to the Bankruptcy Forecasting Problem
Abstract : Artificial neural networks (ANNs) have been widely applied in data mining as a supervised classification technique. The accuracy of this model is mainly provided by its high tolerance to noisy data as well as its ability to classify patterns on which they have not been trained. Moreover, the performance to ANN based models mainly depends both on the ANN parameters and on the quality of input variables. Whereas, an exhaustive search on either appropriate parameters or predictive inputs is very computationally expansive. In this paper, we propose a new hybrid model based on genetic algorithms and artificial neural networks. Our evolutionary classifier is capable of selecting the best set of predictive variables, then, searching for the best neural network classifier and improving classification and generalization accuracies. The designated model was applied to the problem of bankruptcy forecasting, experiments have shown very promising results for the bankruptcy prediction in terms of predictive accuracy and adaptability.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-01262350
Contributor : Coordination Episciences Iam Connect in order to contact the contributor
Submitted on : Tuesday, January 26, 2016 - 4:05:13 PM
Last modification on : Wednesday, October 30, 2019 - 4:34:07 PM
Long-term archiving on: : Wednesday, April 27, 2016 - 1:14:24 PM
File
arima00605.pdf
Publisher files allowed on an open archive
Identifiers
Collections
Citation
M.A. Esseghir. New Evolutionary Classifier Based on Genetic Algorithms and Neural Networks: Application to the Bankruptcy Forecasting Problem. Revue Africaine de la Recherche en Informatique et Mathématiques Appliquées, INRIA, 2007, Volume 6, april 2007, joint Special Issue ARIMA/SACJ on Advances in end-user data mining techniques, pp.57-68. ⟨10.46298/arima.1879⟩. ⟨hal-01262350⟩
Share
Metrics
Record views
78
Files downloads
680
