The effect of body–mind relaxation meditation induction on major depressive disorder: A resting-state fMRI study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Affective Disorders Année : 2015
Background: Meditation has been increasingly evaluated as an important complementary therapeutic tool for the treatment of depression. The present study employed resting state functional magnetic resonance imaging (rs-fMRI) to examine the effect of body mind relaxation meditation induction (BMRMI) on the brain activity of depressed patients and to investigate possible mechanisms of action for this complex intervention. Method: 21 major depressive disorder patients (MDDs) and 24 age and gender-matched healthy controls (HCs) received rs-fMRI scans at baseline and after listening to a selection of audio designed to induce body-mind relaxation meditation. The rs-fMRI data were analyzed using Matlab toolbox to obtain the amplitude of low-frequency fluctuations (ALFF) of the BOLD signal for the whole brain. A mixed-design repeated measures analysis of variance (ANOVA) was performed On the whole brain to Find which brain regions were affected by the BMRMI An additional functional connectivity analysis was used to identify any atypical connection patterns after the BMRMI. Results: After the BMRMI experience, both the MDDs and HCs showed decreased ALFF values in the bilateral frontal pole (BA10). Additionally, increased functional connectivity from the right dorsal medial prefrontal cortex (dmPFC) to the left dorsal lateral prefrontal cortex (dlPFC) and the left lateral orbitofrontal cortex (OFC) was identified only in the MDDs after the BMRMI. Limitation: in order to exclude the impact of other events on the participants brain activity. the Hamilton Rating Scales for Depression (HDRS) was not measured after the body-mind relaxation induction. Conclusion: Our findings support the hypothesis that body-mind relaxation meditation induction may regulate the activities of the prefrontal cortex and thus may have the potential to help patients construct reappraisal strategies that can modulate the brain activity in multiple emotion-processing systems.
hal-01262656 , version 1 (27-01-2016)
Fangfang Chen, Xueyu Lv, Jiliang Fang, Shan Yu, Jing Sui, et al.. The effect of body–mind relaxation meditation induction on major depressive disorder: A resting-state fMRI study. Journal of Affective Disorders, 2015, 183, pp.75 - 82. ⟨10.1016/j.jad.2015.04.030⟩. ⟨hal-01262656⟩
145 Consultations
0 Téléchargements
