Van der Vorst. Templates for the Solution of Linear Systems: Building Blocks for Iterative Methods, 1994. ,
A Residual Replacement Strategy for Improving the Maximum Attainable Accuracy of $s$-Step Krylov Subspace Methods, SIAM Journal on Matrix Analysis and Applications, vol.35, issue.1, pp.22-43, 2014. ,
DOI : 10.1137/120893057
Avoiding Communication in Nonsymmetric Lanczos-Based Krylov Subspace Methods, SIAM Journal on Scientific Computing, vol.35, issue.5, pp.42-61, 2013. ,
DOI : 10.1137/120881191
s-step iterative methods for symmetric linear systems, Journal of Computational and Applied Mathematics, vol.25, issue.2, pp.153-168, 1989. ,
DOI : 10.1016/0377-0427(89)90045-9
URL : http://doi.org/10.1016/0377-0427(89)90045-9
Block s-step Krylov iterative methods. Numerical Linear Algebra with Applications, pp.3-15, 2010. ,
DOI : 10.1002/nla.643
Parallel iterative S-step methods for unsymmetric linear systems, Parallel Computing, vol.22, issue.5, pp.623-641, 1996. ,
DOI : 10.1016/0167-8191(96)00022-1
A parallel variant of GMRES(m), Proceedings of the 13th IMACS World Congress on Computational and Applied Mathematics, 1991. ,
Reducing the effect of global communication in GMRES(m) and CG on parallel distributed memory computers, Applied Numerical Mathematics, vol.18, issue.4, pp.441-459, 1995. ,
Parallel numerical linear algebra, Acta Numerica, vol.10, pp.111-197, 1993. ,
DOI : 10.1007/BF01932738
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.368.1446
Toward a new metric for ranking high performance computing systems, Sandia National Laboratories Technical Report, pp.2013-4744, 2013. ,
HPCG benchmark: a new metric for ranking high performance computing systems, 2015. ,
DOI : 10.1093/nsr/nwv084
Non-blocking preconditioned Conjugate Gradient methods for extreme-scale computing, Conference proceedings. 17th Copper Mountain Conference on Multigrid Methods, 2015. ,
DOI : 10.1109/sc.2016.17
A parallel GMRES version for general sparse matrices, Electronic Transactions on Numerical Analysis, vol.3, issue.12, pp.160-176, 1995. ,
Hiding Global Communication Latency in the GMRES Algorithm on Massively Parallel Machines, SIAM Journal on Scientific Computing, vol.35, issue.1, pp.48-71, 2013. ,
DOI : 10.1137/12086563X
Hiding global synchronization latency in the preconditioned Conjugate Gradient algorithm, Parallel Computing, vol.40, issue.7, pp.224-238, 2014. ,
DOI : 10.1016/j.parco.2013.06.001
Behavior of slightly perturbed Lanczos and conjugate-gradient recurrences, Linear Algebra and its Applications, vol.113, pp.7-63, 1989. ,
DOI : 10.1016/0024-3795(89)90285-1
Estimating the Attainable Accuracy of Recursively Computed Residual Methods, SIAM Journal on Matrix Analysis and Applications, vol.18, issue.3, pp.535-551, 1997. ,
DOI : 10.1137/S0895479895284944
Accuracy of Two Three-term and Three Two-term Recurrences for Krylov Space Solvers, SIAM Journal on Matrix Analysis and Applications, vol.22, issue.1, pp.213-229, 2000. ,
DOI : 10.1137/S0895479897331862
Finding Structure with Randomness: Probabilistic Algorithms for Constructing Approximate Matrix Decompositions, SIAM Review, vol.53, issue.2, pp.217-288, 2011. ,
DOI : 10.1137/090771806
Methods of Conjugate Gradients for solving linear systems, Journal of Research of the National Bureau of Standards, vol.14, issue.6, 1952. ,
Accuracy and stability of numerical algorithms, SIAM, 2002. ,
DOI : 10.1137/1.9780898718027
URL : http://eprints.ma.man.ac.uk/238/04/covered/MIMS_ep2006_75_Book_Covers.pdf
Krylov Subspace Methods: Principles and Analysis, 2012. ,
DOI : 10.1093/acprof:oso/9780199655410.001.0001
The Lanczos and conjugate gradient algorithms in finite precision arithmetic, Acta Numerica, vol.15, pp.471-542, 2006. ,
DOI : 10.1017/S096249290626001X
On the convergence rate of the conjugate gradients in presence of rounding errors, Numerische Mathematik, vol.48, issue.156, pp.301-317, 1993. ,
DOI : 10.1007/BF01385754
The computation of eigenvalues and eigenvectors of very large sparse matrices, 1971. ,
Computational Variants of the Lanczos Method for the Eigenproblem, IMA Journal of Applied Mathematics, vol.10, issue.3, pp.373-381, 1972. ,
DOI : 10.1093/imamat/10.3.373
Error Analysis of the Lanczos Algorithm for Tridiagonalizing a Symmetric Matrix, IMA Journal of Applied Mathematics, vol.18, issue.3, pp.341-349, 1976. ,
DOI : 10.1093/imamat/18.3.341
Accuracy and effectiveness of the Lanczos algorithm for the symmetric eigenproblem, Linear Algebra and its Applications, vol.34, pp.235-258, 1980. ,
DOI : 10.1016/0024-3795(80)90167-6
Zuverl????lich berechnete Residuen in hybriden Bi-CG Verfahren, Computing, vol.15, issue.2, pp.141-163, 1996. ,
DOI : 10.1007/BF02309342
Differences in the Effects of Rounding Errors in Krylov Solvers for Symmetric Indefinite Linear Systems, SIAM Journal on Matrix Analysis and Applications, vol.22, issue.3, pp.726-751, 2001. ,
DOI : 10.1137/S0895479897323087
Relaxationsmethoden bester Strategie zur L??sung linearer Gleichungssysteme, Commentarii Mathematici Helvetici, vol.29, issue.1, pp.157-179, 1955. ,
DOI : 10.1007/BF02564277
URL : http://www.digizeitschriften.de/download/PPN358147735_0029/PPN358147735_0029___log14.pdf
Tich`y. On error estimation in the Conjugate Gradient method and why it works in finite precision computations, Electronic Transactions on Numerical Analysis, vol.13, pp.56-80, 2002. ,
Analysis of the finite precision bi-conjugate gradient algorithm for nonsymmetric linear systems, Mathematics of Computation, vol.69, issue.232, pp.1559-1575, 2000. ,
DOI : 10.1090/S0025-5718-99-01171-0
Residual Replacement Strategies for Krylov Subspace Iterative Methods for the Convergence of True Residuals, SIAM Journal on Scientific Computing, vol.22, issue.3, pp.835-852, 2000. ,
DOI : 10.1137/S1064827599353865
Rounding errors in algebraic processes, Courier Corporation, 1994. ,
