Journal articles
Shape optimization for the Stokes equations using topological sensitivity analysis
Abstract : In this paper, we consider a shape optimization problem related to the Stokes equations. The proposed approach is based on a topological sensitivity analysis. It consists in an asymptotic expansion of a cost function with respect to the insertion of a small obstacle in the domain. The theoretical part of this work is discussed in both two and three dimensional cases. In the numerical part, we use this approach to optimize the shape of the tubes that connect the inlet to the outlets of the cavity maximizing the outflow rate.
Document type :
Journal articles
Complete list of metadata
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/hal-01263434
Contributor : Coordination Episciences Iam Connect in order to contact the contributor
Submitted on : Wednesday, January 27, 2016 - 5:14:07 PM
Last modification on : Wednesday, October 28, 2020 - 12:10:04 PM
Long-term archiving on: : Thursday, April 28, 2016 - 11:22:27 AM
File
arima00516.pdf
Publisher files allowed on an open archive
Identifiers
Collections
Citation
Hassine Maatoug. Shape optimization for the Stokes equations using topological sensitivity analysis. Revue Africaine de la Recherche en Informatique et Mathématiques Appliquées, INRIA, 2006, Volume 5, Special Issue TAM TAM'05, november 2006, pp.216-229. ⟨10.46298/arima.1865⟩. ⟨hal-01263434⟩
Share
Metrics
Record views
79
Files downloads
531
