An alternative two-phase flow correction for aeration process in lakes, Int. J. Comput. Fluid. Dyn, vol.19, issue.4, pp.289-298, 2005. ,
The effects of mixing on the distibution of dissolved oxygen in the surface waters of a lakes, Centre of water research Report ,
fluid dynamic theory of two-phase flow. « Collection de la direction des études de recherche d'électricité de france, 1975. ,
Galerkin and the particule method for convection-diffusion equation on the Navier-Stokes equation, Lectures in Applied Mathematics, vol.28, pp.547-565, 1991. ,
