Abstract : The design of safety-critical embedded systems such as those used in avionics still involves largely manual phases. But in avionics the definition of standard interfaces embodied in standards such as ARINC 653 or TTEthernet should allow the definition of fully automatic code generation flows that reduce the costs while improving the quality of the generated code, much like compilers have done when replacing manual assembly coding. In this paper, we briefly present such a fully automatic implementation tool, called Lopht, for ARINC653-based time-triggered systems, and then explain how it is currently extended to include support for TTEthernet networks.
https://hal.inria.fr/hal-01264687
Contributor : Dumitru Potop-Butucaru <>
Submitted on : Friday, January 29, 2016 - 3:34:56 PM Last modification on : Friday, January 8, 2021 - 11:30:04 AM Long-term archiving on: : Friday, November 11, 2016 - 8:34:05 PM
Raul Adrian Gorcitz, Thomas Carle, David Lesens, David Monchaux, Dumitru Potop-Butucaru, et al.. Automatic implementation of TTEthernet-based time-triggered avionics applications. DASIA 2015, Eurospace, May 2015, Barcelone, Spain. ⟨hal-01264687⟩
