Advanced object-oriented paradigms for parallel computational mechanics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2011
Dominique Eyheramendy
Fabienne Oudin
  • Fonction : Auteur
This paper shows a tentative integration of theory and applications in a single framework based on a Java approach in the context of parallel computing. We develop a unifying Java paradigm for integrating variational statements in a Java computational application. At last, we present Java technologies in the context of concurrent and distributed application.
Fichier non déposé
hal-01265399 , version 1 (01-02-2016)
  • HAL Id : hal-01265399 , version 1
Dominique Eyheramendy, Roy Saad, Fabienne Oudin. Advanced object-oriented paradigms for parallel computational mechanics. Ivany, Topping. Trends in parallel, distributed, grid and cloud computing for engineering, 27, Saxe-Cobourg Publications, pp.380, 2011, Computational Science, Engineering & Technology Series, 978-1-874672-53-1. ⟨hal-01265399⟩
32 Consultations
0 Téléchargements
