Sub-cortical brain structure segmentation using F-CNN's - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we propose a deep learning approach for segmenting sub-cortical structures of the human brain in Magnetic Resonance (MR) image data. We draw inspiration from a state-of-the-art Fully-Convolutional Neural Network (F-CNN) architecture for semantic segmentation of objects in natural images, and adapt it to our task. Unlike previous CNN-based methods that operate on image patches, our model is applied on a full blown 2D image, without any alignment or registration steps at testing time. We further improve segmentation results by interpreting the CNN output as potentials of a Markov Random Field (MRF), whose topology corresponds to a volumetric grid. Alpha-expansion is used to perform approximate inference imposing spatial volumetric homogeneity to the CNN priors. We compare the performance of the proposed pipeline with a similar system using Random Forest-based priors, as well as state-of-art segmentation algorithms, and show promising results on two different brain MRI datasets.
isbi2016_final.pdf (504.31 Ko) Télécharger le fichier
hal-01265500 , version 1 (05-02-2016)
Paternité - Pas d'utilisation commerciale - Pas de modification
Mahsa Shakeri, Stavros Tsogkas, Enzo Ferrante, Sarah Lippe, Samuel Kadoury, et al.. Sub-cortical brain structure segmentation using F-CNN's. ISBI 2016 - International Symposium on Biomedical Imaging, 2016, Prague, Czech Republic. ⟨hal-01265500⟩
862 Consultations
949 Téléchargements
