Linear Diophantine equations over polynomials and soft decoding of Reed-Solomon codes, FOCS'02, pp.439-448, 2002. ,
Linear Diophantine Equations Over Polynomials and Soft Decoding of Reed???Solomon Codes, IEEE Transactions on Information Theory, vol.51, issue.7, pp.2257-2265, 2005. ,
DOI : 10.1109/TIT.2005.850097
A reliable method for computing M-Pad?? approximants on arbitrary staircases, Journal of Computational and Applied Mathematics, vol.40, issue.1, pp.19-42, 1992. ,
DOI : 10.1016/0377-0427(92)90039-Z
A Uniform Approach for the Fast Computation of Matrix-Type Pad?? Approximants, SIAM Journal on Matrix Analysis and Applications, vol.15, issue.3, pp.804-823, 1994. ,
DOI : 10.1137/S0895479892230031
Fraction-Free Computation of Matrix Rational Interpolants and Matrix GCDs, SIAM Journal on Matrix Analysis and Applications, vol.22, issue.1, pp.114-144, 2000. ,
DOI : 10.1137/S0895479897326912
Normal forms for general polynomial matrices, Journal of Symbolic Computation, vol.41, issue.6, pp.708-737, 2006. ,
DOI : 10.1016/j.jsc.2006.02.001
Multivariate List Decoding of Evaluation Codes with a Gröbner Basis Perspective, 2008. ,
Faster Algorithms for Multivariate Interpolation With Multiplicities and Simultaneous Polynomial Approximations, IEEE Transactions on Information Theory, vol.61, issue.5, pp.612370-2387, 2015. ,
DOI : 10.1109/TIT.2015.2416068
URL : https://hal.archives-ouvertes.fr/hal-00941435
Approximate common divisors via lattices, Tenth Algorithmic Number Theory Symposium, pp.271-293 ,
DOI : 10.2140/obs.2013.1.271
Ideal forms of Coppersmith's theorem and Guruswami-Sudan list decoding, Advances in Mathematics of Communications, vol.9, issue.3, pp.311-339, 2015. ,
DOI : 10.3934/amc.2015.9.311
Matrix multiplication via arithmetic progressions, Proceedings of the nineteenth annual ACM conference on Theory of computing , STOC '87, pp.251-280, 1990. ,
DOI : 10.1145/28395.28396
Optimally robust private information retrieval, Cryptology ePrint Archive, 2012. ,
Modern Computer Algebra (third edition), 2013. ,
On the complexity of polynomial matrix computations, Proceedings of the 2003 international symposium on Symbolic and algebraic computation , ISSAC '03, pp.135-142, 2003. ,
DOI : 10.1145/860854.860889
Hermite forms of polynomial matrices, 2011. ,
Triangular <mml:math altimg="si1.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mi>x</mml:mi></mml:math>-basis decompositions and derandomization of linear algebra algorithms over <mml:math altimg="si2.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mstyle mathvariant="sans-serif"><mml:mi>K</mml:mi></mml:mstyle><mml:mrow><mml:mo>[</mml:mo><mml:mi>x</mml:mi><mml:mo>]</mml:mo></mml:mrow></mml:math>, Journal of Symbolic Computation, vol.47, issue.4, pp.422-453, 2012. ,
DOI : 10.1016/j.jsc.2011.09.006
Computing hermite forms of polynomial matrices, Proceedings of the 36th international symposium on Symbolic and algebraic computation, ISSAC '11, pp.155-162, 2011. ,
DOI : 10.1145/1993886.1993913
Asymptotically Fast Triangularization of Matrices over Rings, SIAM Journal on Computing, vol.20, issue.6, pp.1068-1083, 1991. ,
DOI : 10.1137/0220067
Sur l'introduction des variables continues dans la théorie des nombres, Journal für die reine und angewandte Mathematik, pp.191-216, 1851. ,
Computing minimal interpolation bases. HAL Open archive -https, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01241781
Fast computation of minimal interpolation bases in Popov form for arbitrary shifts. HAL Open archive -https, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01265983
Linear Systems, 1980. ,
Parallel algorithms for matrix normal forms, Linear Algebra and its Applications, vol.136, pp.189-208, 1990. ,
DOI : 10.1016/0024-3795(90)90028-B
Algebra (Revised Third Edition), 2002. ,
Powers of tensors and fast matrix multiplication, Proceedings of the 39th International Symposium on Symbolic and Algebraic Computation, ISSAC '14, pp.296-303, 2014. ,
DOI : 10.1145/2608628.2608664
On lattice reduction for polynomial matrices, Journal of Symbolic Computation, vol.35, issue.4, pp.377-401, 2003. ,
DOI : 10.1016/S0747-7171(02)00139-6
Invariant Description of Linear, Time-Invariant Controllable Systems, SIAM Journal on Control, vol.10, issue.2, pp.252-264, 1972. ,
DOI : 10.1137/0310020
Normalization of row reduced matrices, Proceedings of the 36th international symposium on Symbolic and algebraic computation, ISSAC '11, pp.297-304, 2011. ,
DOI : 10.1145/1993886.1993931
High-order lifting and integrality certification, Journal of Symbolic Computation, vol.36, issue.3-4, pp.613-648, 2003. ,
DOI : 10.1016/S0747-7171(03)00097-X
Notes on computing minimal approximant bases, Dagstuhl Seminar Proceedings, 2006. ,
Asymptotically fast computation of Hermite normal forms of integer matrices, Proceedings of the 1996 international symposium on Symbolic and algebraic computation , ISSAC '96, pp.259-266, 1996. ,
DOI : 10.1145/236869.237083
A general module theoretic framework for vector M-Padé and matrix rational interpolation, Numer. Algorithms, vol.3, pp.451-462, 1992. ,
Computing Popov and Hermite forms of polynomial matrices, Proceedings of the 1996 international symposium on Symbolic and algebraic computation , ISSAC '96, pp.250-258, 1996. ,
DOI : 10.1145/236869.237082
Efficient algorithms for order basis computation, Journal of Symbolic Computation, vol.47, issue.7, pp.793-819, 2012. ,
DOI : 10.1016/j.jsc.2011.12.009
A fast, deterministic algorithm for computing a Hermite normal form of a polynomial matrix. arXiv e-Print archive http, 2016. ,
Computing minimal nullspace bases, Proceedings of the 37th International Symposium on Symbolic and Algebraic Computation, ISSAC '12, pp.366-373, 2012. ,
DOI : 10.1145/2442829.2442881
A deterministic algorithm for inverting a polynomial matrix, Journal of Complexity, vol.31, issue.2, pp.162-173, 2015. ,
DOI : 10.1016/j.jco.2014.09.004
