, Peggy sends c A as the characteristic polynomial
, Peggy and Victor enter a determinant certificate for rI ? A
, Once convinced, Victor checks that det(rI ? A) ? == c A (r)
, For a random r ? S, in the determinant sub-certificate, rI ? A will be nonsingular if c A (r) = 0, hence with probability ? 1 ? n/|S|. Then det(rI ? A) is certified using the certificate of Figure 5. Best known algorithms for computing the characteristic polynomial, using either quadratic space and fast matrix multiplication or linear space
A uniform approach for the fast computation of matrix-type Padé approximants, SIAM Journal on Matrix Analysis and Applications, vol.15, issue.3, pp.804-823, 1994. ,
Sponge-based pseudo-random number generators, CHES 2010, pp.33-47, 2010. ,
Efficient matrix preconditioners for black box linear algebra, Linear Algebra Appl, pp.119-146, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-02101893
Improved delegation of computation using fully homomorphic encryption, CRYPTO 2010, vol.6223, pp.483-501, 2010. ,
Solving homogeneous linear equations over GF(2) via block Wiedemann algorithm, Mathematics of Computation, vol.62, issue.205, pp.333-350, 1994. ,
Modular Design Of Secure Yet Practical Cryptographic Protocols, 1997. ,
A probabilistic remark on algebraic program testing, Inf. Process. Letters, vol.7, issue.4, pp.193-195, 1978. ,
Certificates for the verification of Wiedemann's Krylov sequence, 2016. ,
Essentially optimal interactive certificates in linear algebra, pp.146-153, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00932846
On randomized Lanczos algorithms, pp.176-183 ,
How to prove yourself: Practical solutions to identification and signature problems, Advances in Cryptology -CRYPTO'86, vol.263, pp.11-15, 1986. ,
Publicly verifiable delegation of large polynomials and matrix computations, with applications, ACM CCS '12, pp.501-512, 2012. ,
Mathematical Foundations of Computer Science, Lecture Notes in Computer Science, vol.74, pp.57-69, 1979. ,
Using fully homomorphic hybrid encryption to minimize non-interative zero-knowledge proofs, Journal of Cryptology, pp.1-24, 2014. ,
Delegating computation: interactive proofs for muggles, pp.113-122, 2008. ,
Analysis of Coppersmith's block Wiedemann algorithm for the parallel solution of sparse linear systems, Mathematics of Computation, vol.64, issue.210, pp.777-806, 1995. ,
Processor efficient parallel solution of linear systems over an abstract field, ACM SPAA '91, pp.180-191, 1991. ,
On the complexity of computing determinants, Computational Complexity, vol.13, issue.3, pp.91-130, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-02102099
Exact certification in global polynomial optimization via sums-of-squares of rational functions with rational coefficients, Journal of Symbolic Computation, vol.47, issue.1, pp.1-15, 2012. ,
Quadratic-time certificates in linear algebra, pp.171-176, 2011. ,
, ISSAC'97, 1997.
, EUROSAM '79, International Symposium on Symbolic and Algebraic Computation, vol.72, 1979.
, SHA-3 Standard: Permutation-Based Hash and Extendable-Output Functions, NIST. FIPS Publication, vol.202, 2015.
Pinocchio: Nearly practical verifiable computation, IEEE SP '13, pp.238-252, 2013. ,
Probabilistic algorithms for verification of polynomial identities, pp.200-215 ,
Time-optimal interactive proofs for circuit evaluation, Lecture Notes in Computer Science, vol.8043, issue.13, pp.71-89, 2013. ,
Further analysis of Coppersmith's block Wiedemann algorithm for the solution of sparse linear systems, pp.32-39 ,
Computing the Frobenius normal form of a sparse matrix, CASC'00, pp.395-407, 2000. ,
Solving sparse linear equations over finite fields, IEEE Transactions on Information Theory, vol.32, issue.1, pp.54-62, 1986. ,
Probabilistic algorithms for sparse polynomials, pp.216-226 ,
