Constantsize structure-preserving signatures: Generic constructions and simple assumptions, Asiacrypt 2012, number 7658, pp.4-24, 2012. ,
Structurepreserving signatures and commitments to group elements, pp.209-236, 2010. ,
Efficient Lattice (H)IBE in the Standard Model, Eurocrypt, pp.553-572, 2010. ,
DOI : 10.1007/978-3-642-13190-5_28
Generating Shorter Bases for Hard Random Lattices, STACS 2009, 2009. ,
DOI : 10.1007/s00224-010-9278-3
URL : https://hal.archives-ouvertes.fr/inria-00359718
Multiparty Computation with Low Communication, Computation and Interaction via Threshold FHE, Eurocrypt 2012, pp.483-501, 2012. ,
DOI : 10.1007/978-3-642-29011-4_29
A Practical and Provably Secure Coalition-Resistant Group Signature Scheme, pp.255-270, 2000. ,
DOI : 10.1007/3-540-44598-6_16
Improved Security Proofs in Lattice-Based Cryptography: Using the R??nyi Divergence Rather Than the Statistical Distance, Asiacrypt 2015, pp.3-24, 2015. ,
DOI : 10.1007/978-3-662-48797-6_1
New bounds in some transference theorems in the geometry of numbers, Mathematische Annalen, vol.68, issue.1, pp.625-635, 1993. ,
DOI : 10.1007/BF01445125
Randomizable Proofs and Delegatable Anonymous Credentials, pp.108-125, 2009. ,
DOI : 10.1007/978-3-642-03356-8_7
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.215.4084
P-signatures and Noninteractive Anonymous Credentials, TCC 2008, number 4948 in LNCS, pp.356-374, 2008. ,
DOI : 10.1007/978-3-540-78524-8_20
URL : https://lirias.kuleuven.be/bitstream/123456789/228640/2/article-1004.pdf
Foundations of Group Signatures: Formal Definitions, Simplified Requirements, and a Construction Based on General Assumptions, Eurocrypt 2003, number 2656, pp.614-629, 2003. ,
DOI : 10.1007/3-540-39200-9_38
Random oracles are practical, Proceedings of the 1st ACM conference on Computer and communications security , CCS '93, pp.62-73, 1993. ,
DOI : 10.1145/168588.168596
Foundations of Group Signatures: The Case of Dynamic Groups, CT-RSA 2005, number 3376 in LNCS, pp.136-153, 2005. ,
DOI : 10.1007/978-3-540-30574-3_11
Better Zero-Knowledge Proofs for Lattice Encryption and Their Application to Group Signatures, Asiacrypt 2014, pp.551-572, 2014. ,
DOI : 10.1007/978-3-662-45611-8_29
URL : https://hal.archives-ouvertes.fr/hal-01084737
Efficient Zero-Knowledge Proofs for Commitments from Learning with Errors over Rings, ESORICS 2015, 2015. ,
DOI : 10.1007/978-3-319-24174-6_16
URL : https://hal.archives-ouvertes.fr/hal-01214722
Confined Guessing: New Signatures From Standard Assumptions, Journal of Cryptology, vol.28, issue.1, pp.176-208, 2015. ,
DOI : 10.1007/s00145-014-9183-z
Efficient Selective-ID Secure Identity-Based Encryption Without Random Oracles, Eurocrypt, pp.223-238, 2004. ,
DOI : 10.1007/978-3-540-24676-3_14
Short Group Signatures, LNCS, vol.3152, pp.41-55, 2004. ,
DOI : 10.1007/978-3-540-28628-8_3
Lattice Mixing and Vanishing Trapdoors: A Framework for Fully Secure Short Signatures and More, PKC 2010, pp.499-517, 2010. ,
DOI : 10.1007/978-3-642-13013-7_29
Compact Group Signatures Without Random Oracles, Eurocrypt, pp.427-444, 2006. ,
DOI : 10.1007/11761679_26
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.363.1318
Full-Domain Subgroup Hiding and Constant-Size Group Signatures, PKC 2007, pp.1-15, 2007. ,
DOI : 10.1007/978-3-540-71677-8_1
URL : http://ai.stanford.edu/~xb/pkc07/fullgrpsigs.pdf
A Framework for Efficient Signatures, Ring Signatures and Identity Based Encryption in the Standard Model, IACR Cryptology ePrint Archive, p.86, 2010. ,
Classical hardness of learning with errors, Proceedings of the 45th annual ACM symposium on Symposium on theory of computing, STOC '13, pp.575-584, 2013. ,
DOI : 10.1145/2488608.2488680
URL : https://hal.archives-ouvertes.fr/hal-00922194
Design Validations for Discrete Logarithm Based Signature Schemes, PKC 2000, pp.276-292, 2000. ,
DOI : 10.1007/978-3-540-46588-1_19
Efficient attributes for anonymous credentials, ACM-CCS 2008, pp.345-356, 2008. ,
Compact E-Cash, Eurocrypt 2005, number 3494 in LNCS, pp.302-321, 2005. ,
DOI : 10.1007/11426639_18
On the Portability of Generalized Schnorr Proofs, Eurocrypt 2009, number 5479 in LNCS, 2009. ,
DOI : 10.1007/11556992_11
Formal Treatment of Privacy-Enhancing Credential Systems, SAC 2015, 2015. ,
DOI : 10.1007/978-3-642-02384-2_13
An Efficient System for Non-transferable Anonymous Credentials with Optional Anonymity Revocation, Eurocrypt 2001, number 2045 in LNCS, pp.93-118, 2001. ,
DOI : 10.1007/3-540-44987-6_7
Dynamic Accumulators and Application to Efficient Revocation of Anonymous Credentials, LNCS, vol.2442, pp.61-76, 2002. ,
DOI : 10.1007/3-540-45708-9_5
A Signature Scheme with Efficient Protocols, SCN 2002, number 2576 in LNCS, pp.268-289, 2002. ,
DOI : 10.1007/3-540-36413-7_20
Signature Schemes and Anonymous Credentials from Bilinear Maps, number 3152 in LNCS, pp.56-72, 2004. ,
DOI : 10.1007/978-3-540-28628-8_4
Fully Anonymous Attribute Tokens from Lattices, SCN 2012, pp.57-75, 2012. ,
DOI : 10.1007/978-3-642-32928-9_4
Bonsai trees, or how to delegate a lattice basis, Eurocrypt, pp.523-552, 2010. ,
Group Encryption: Non-interactive Realization in the Standard Model, Asiacrypt, pp.179-196, 2009. ,
DOI : 10.1007/978-3-642-10366-7_11
Algebraic MACs and Keyed-Verification Anonymous Credentials, Proceedings of the 2014 ACM SIGSAC Conference on Computer and Communications Security, CCS '14, pp.1205-1216, 2014. ,
DOI : 10.1145/2660267.2660328
Security without identification: transaction systems to make big brother obsolete, Communications of the ACM, vol.28, issue.10, pp.1030-1044, 1985. ,
DOI : 10.1145/4372.4373
Group Signatures, Eurocrypt, pp.257-265, 1991. ,
DOI : 10.1007/3-540-46416-6_22
Efficient Concurrent Zero-Knowledge in the Auxiliary String Model, Eurocrypt, pp.418-430, 2000. ,
DOI : 10.1007/3-540-45539-6_30
Public-Key??Encryption??with Non-interactive??Opening, CT-RSA 2008, pp.239-255, 2008. ,
DOI : 10.1007/978-3-540-79263-5_15
Non-interactive Proofs for Integer Multiplication, Eurocrypt, pp.412-429, 2007. ,
DOI : 10.1007/978-3-540-72540-4_24
Dynamic Fully Anonymous Short Group Signatures, number 4341 in LNCS, pp.193-210, 2006. ,
DOI : 10.1007/11958239_13
How To Prove Yourself: Practical Solutions to Identification and Signature Problems, pp.186-194, 1986. ,
DOI : 10.1007/3-540-47721-7_12
Fully homomorphic encryption using ideal lattices, Proceedings of the 41st annual ACM symposium on Symposium on theory of computing, STOC '09, pp.169-178, 2009. ,
DOI : 10.1145/1536414.1536440
Trapdoors for hard lattices and new cryptographic constructions, Proceedings of the fourtieth annual ACM symposium on Theory of computing, STOC 08, pp.197-206, 2008. ,
DOI : 10.1145/1374376.1374407
The knowledge complexity of interactive proof-systems, STOC 1985, pp.291-304, 1985. ,
Attribute-based encryption for circuits, STOC 2013, pp.545-554, 2013. ,
Predicate Encryption for Circuits from LWE, Crypto 2015, number 9216, pp.503-523, 2015. ,
DOI : 10.1007/978-3-662-48000-7_25
URL : https://hal.archives-ouvertes.fr/hal-01220191
A Group Signature Scheme from Lattice Assumptions, Asiacrypt 2010, pp.395-412, 2010. ,
DOI : 10.1007/978-3-642-17373-8_23
Universally Composable Adaptive Oblivious Transfer, Asiacrypt number 5350 in LNCS, pp.179-197, 2008. ,
DOI : 10.1007/3-540-69053-0_18
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.215.7524
Fully Anonymous Group Signatures Without Random Oracles, Asiacrypt, pp.164-180, 2007. ,
DOI : 10.1007/978-3-540-76900-2_10
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.304.6315
Efficient Non-interactive Proof Systems for Bilinear Groups, Eurocrypt, pp.415-432, 2008. ,
DOI : 10.1007/978-3-540-78967-3_24
Short and Stateless Signatures from the RSA Assumption, LNCS, vol.5677, pp.654-670, 2009. ,
DOI : 10.1007/978-3-642-03356-8_38
Concurrently Secure Identification Schemes Based on the Worst-Case Hardness of Lattice Problems, LNCS, vol.42, issue.6, pp.372-389, 2008. ,
DOI : 10.1007/978-3-540-30144-8_28
Group Encryption, Asiacrypt 2007, number 4833 in LNCS, pp.181-199, 2007. ,
DOI : 10.1007/978-3-540-76900-2_11
Group Signatures with Efficient Concurrent Join, Eurocrypt 2005, number 3494 in LNCS, pp.198-214, 2005. ,
DOI : 10.1007/11426639_12
Secure scalable group signature with dynamic joins and separable authorities, International Journal of Security and Networks, vol.1, issue.1/2, pp.24-45, 2006. ,
DOI : 10.1504/IJSN.2006.010821
Lattice-Based Group Signatures with Logarithmic Signature Size, Asiacrypt 2013, pp.41-61, 2013. ,
DOI : 10.1007/978-3-642-42045-0_3
URL : https://hal.archives-ouvertes.fr/hal-00920420
Lattice-Based Group Signature Scheme with Verifier-Local Revocation, PKC 2014, pp.345-361, 2014. ,
DOI : 10.1007/978-3-642-54631-0_20
URL : https://hal.archives-ouvertes.fr/hal-00983084
GGHLite: More Efficient Multilinear Maps from Ideal Lattices, Eurocrypt 2014, pp.239-256, 2014. ,
DOI : 10.1007/978-3-642-55220-5_14
URL : https://hal.archives-ouvertes.fr/hal-00983179
Zero-knowledge arguments for latticebased accumulators: Logarithmic-size ring signatures and group signatures without trapdoors, Eurocrypt 2016, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01314642
Improved Zero-Knowledge Proofs of Knowledge for the ISIS Problem, and Applications, PKC 2013, pp.107-124, 2013. ,
DOI : 10.1007/978-3-642-36362-7_8
URL : https://hal.archives-ouvertes.fr/hal-00767548
Group Signatures from Lattices: Simpler, Tighter, Shorter, Ring-Based, PKC 2015, pp.427-449, 2015. ,
DOI : 10.1007/978-3-662-46447-2_19
Lattice-Based Identification Schemes Secure Under Active Attacks, Public Key Cryptography, pp.162-179, 2008. ,
DOI : 10.1007/978-3-540-78440-1_10
On ideal lattices and learning with errors over rings, Eurocrypt 2010, pp.1-23, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00921792
Trapdoors for Lattices: Simpler, Tighter, Faster, Smaller, Eurocrypt 2012, pp.700-718, 2012. ,
DOI : 10.1007/978-3-642-29011-4_41
Simpler Efficient Group Signatures from Lattices, PKC 2015, pp.401-426, 2015. ,
DOI : 10.1007/978-3-662-46447-2_18
URL : https://hal.archives-ouvertes.fr/hal-01256013
Streaming Authenticated Data Structures, EUROCRYPT 2013, pp.353-370, 2013. ,
DOI : 10.1007/978-3-642-38348-9_22
Public-key cryptosystems from the worst-case shortest vector problem, Proceedings of the 41st annual ACM symposium on Symposium on theory of computing, STOC '09, pp.333-342, 2009. ,
DOI : 10.1145/1536414.1536461
A decade of lattice cryptography. Cryptology ePrint Archive, 2015. ,
On lattices, learning with errors, random linear codes, and cryptography, STOC 2005, pp.84-93, 2005. ,
How to Leak a Secret, Asiacrypt, pp.552-565, 2001. ,
DOI : 10.1007/3-540-45682-1_32
On the Security of Dynamic Group Signatures: Preventing Signature Hijacking, PKC 2012, pp.715-732, 2012. ,
DOI : 10.1007/978-3-642-30057-8_42
A new paradigm for public key identification. Information Theory, IEEE Transactions on, vol.42, issue.6, pp.1757-1768, 1996. ,
