Method and system for user speed estimation in wireless networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Brevet Année : 2013
A method for estimating the speed of a user equipment connected to a base station of a wireless network, the method comprising the following steps: - performing signal strength measurements (S) of a radio signal transmitted between the user equipment and the base station; - performing a spectral analysis (11) of the signal strength measurements; - determining the frequency of a local maximum in the power spectrum of the signal strength measurements; - estimating (12), from previously established reference data, the speed of the user equipment that corresponds to the determined frequency, the reference data associating a given user equipment speed with a certain determined frequency.
Fichier non déposé
hal-01267481 , version 1 (04-02-2016)
  • HAL Id : hal-01267481 , version 1
Majed Haddad, Veronique Capdevielle, Afef Feki, Eitan Altman. Method and system for user speed estimation in wireless networks. France, Patent n° : EP2793517, WO/2014/170073, US20160080095. 2013. ⟨hal-01267481⟩
Collections
INRIA INRIA2
75 Consultations
0 Téléchargements
