Abstract : A method for estimating the speed of a user equipment connected to a base station of a wireless network, the method comprising the following steps: - measuring the power of a signal transmitted between the user equipment and the base station; - computing the derivative of the measured signal power with respect to time; - computing the standard deviation of the computed derivative; - estimating, from previously established reference data, the speed of the user equipment that corresponds to the computed standard deviation, the reference data associating a given user equipment speed with a certain computed standard deviation.
https://hal.inria.fr/hal-01267534
Contributor : Sara Alouf <>
Submitted on : Thursday, February 4, 2016 - 3:18:30 PM Last modification on : Saturday, January 27, 2018 - 1:31:41 AM
