ERRATUM: A Continuous Exact l0 penalty (CEL0) for least squares regularized problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Imaging Sciences Année : 2016
Emmanuel Soubies
Laure Blanc-Féraud
Lemma 4.4 in [E. Soubies, L. Blanc-Féraud and G. Aubert, SIAM J. Imaging Sci., 8 (2015), pp. 1607-1639] is wrong for local minimizers of the CEL0 functional. The argument used to conclude the proof of this lemma is not sufficient in the case of local minimizers. In this note, we supply a revision of this Lemma where new results are established for local minimizers. Theorem 4.8 in that paper remains unchanged but the proof has to be rewritten according to the new version of the lemma. Finally, some remarks of this paper are also rewritten using the corrected lemma.
Erratum_SIIMS_CEL0_Soubies_BlancFeraud_Aubert.pdf (132.99 Ko) Télécharger le fichier
hal-01267679 , version 1 (04-02-2016)
Emmanuel Soubies, Laure Blanc-Féraud, Gilles Aubert. ERRATUM: A Continuous Exact l0 penalty (CEL0) for least squares regularized problem. SIAM Journal on Imaging Sciences, 2016, 9 (1), pp.490-494. ⟨10.1137/15M1038384⟩. ⟨hal-01267679⟩
432 Consultations
104 Téléchargements
