Direct and Fast Ray Tracing of NURBS Surfaces, 2006 IEEE Symposium on Interactive Ray Tracing, pp.161-168, 2006. ,
DOI : 10.1109/RT.2006.280227
A mapping-independent primitive for the triangulation of parametric surfaces, Graphical Models, vol.65, issue.5, pp.260-273, 2003. ,
DOI : 10.1016/S1524-0703(03)00048-1
A robust conforming NURBS tessellation for industrial applications based on a mesh generation approach, Computer-Aided Design, vol.63, issue.0, pp.26-38, 2015. ,
DOI : 10.1016/j.cad.2014.12.009
Curve/surface intersection problem by means of matrix representations, Proc. Conf. Symbolic Numeric Computation, SNC '09, pp.71-78, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00418403
Ray tracing of optical systems using NURBS surfaces, Physica Scripta, vol.82, issue.1, p.15403, 2010. ,
DOI : 10.1088/0031-8949/82/01/015403
Provably good sampling and meshing of surfaces, Graphical Models, vol.67, issue.5, pp.405-451, 2005. ,
DOI : 10.1016/j.gmod.2005.01.004
URL : https://hal.archives-ouvertes.fr/hal-00488829
Fitting ideals and multiple points of surface parameterizations, Journal of Algebra, vol.420, pp.486-508, 2014. ,
DOI : 10.1016/j.jalgebra.2014.07.028
URL : https://hal.archives-ouvertes.fr/hal-00874221
Particle systems for adaptive, isotropic meshing of CAD models, Engineering with Computers, vol.28, issue.5, pp.331-344, 2012. ,
DOI : 10.1007/s00366-012-0266-x
Repairing and meshing imperfect shapes with Delaunay refinement, 2009 SIAM/ACM Joint Conference on Geometric and Physical Modeling on, SPM '09, pp.25-33, 2009. ,
DOI : 10.1145/1629255.1629259
Implicit matrix representations of rational Bézier curves and surfaces, Computer-Aided Design, vol.46, pp.14-24, 2014. ,
Ray tracing of spline surfaces: Bézier clipping, Chebyshev boxing, and bounding volume hierarchy ? a critical comparison with new results. The Visual Computer, pp.265-282, 1997. ,
Delaunay Mesh Generation. Chapman & Hall/CRC computer and information science series, 2012. ,
The generalized Schur decomposition of an arbitrary pencil A--??B---robust software with error bounds and applications. Part I: theory and algorithms, ACM Transactions on Mathematical Software, vol.19, issue.2, pp.160-174, 1993. ,
DOI : 10.1145/152613.152615
Finding intersections of B-spline represented geometries using recursive subdivision techniques, Computer Aided Geometric Design, vol.2, issue.1-3, pp.189-195, 1985. ,
DOI : 10.1016/0167-8396(85)90024-X
Recursive Subdivision and Iteration in Intersections and Related Problems, Mathematical Methods in Computer Aided Geometric Design, pp.207-214, 1989. ,
DOI : 10.1016/B978-0-12-460515-2.50019-6
The eigenstructure of an arbitrary polynomial matrix: computational aspects, Linear Algebra and its Applications, vol.50, issue.0, pp.545-579, 1983. ,
DOI : 10.1016/0024-3795(83)90069-1
Robust and numerically stable B??zier clipping method for ray tracing NURBS surfaces, Proceedings of the 21st spring conference on Computer graphics , SCCG '05, pp.127-135, 2005. ,
DOI : 10.1145/1090122.1090144
Mesh Generation: Application to Finite Elements, ISTE, 2007. ,
Gmsh: a three-dimensional finite element mesh generator with built-in pre-and postprocessing facilities, 2014. ,
Matrix computations, 1996. ,
Eigen v3, 2010. ,
GPU-based trimming and tessellation of NURBS and T-Spline surfaces, ACM Transactions on Graphics, vol.24, issue.3, pp.1016-1023, 2005. ,
DOI : 10.1145/1073204.1073305
A tessellation algorithm for the representation of trimmed nurbs surfaces with arbitrary trimming curves, Computer-Aided Design, vol.28, issue.6-7, pp.6-7461, 1996. ,
DOI : 10.1016/0010-4485(95)00043-7
CGALmesh, ACM Transactions on Mathematical Software, vol.41, issue.4, 2014. ,
DOI : 10.1145/2699463
URL : https://hal.archives-ouvertes.fr/hal-01071759
Practical Ray Tracing of Trimmed NURBS Surfaces, Journal of Graphics Tools, vol.19, issue.3, pp.27-52, 2000. ,
DOI : 10.1016/0146-664X(80)90040-4
Hybrid ray tracing and path tracing of Bezier surfaces using a mixed hierarchy, Proceedings of the Eighth Indian Conference on Computer Vision, Graphics and Image Processing, ICVGIP '12, pp.1-8, 2012. ,
DOI : 10.1145/2425333.2425368
Tessellating trimmed NURBS surfaces, Computer-Aided Design, vol.27, issue.1, pp.16-26, 1995. ,
The NURBS Book, 1997. ,
Geometry-based triangulation of trimmed NURBS surfaces, Computer-Aided Design, vol.30, issue.1, pp.11-18, 1998. ,
Curve intersection using Bézier clipping, Computer-Aided Design, vol.22, issue.9, pp.538-549, 1990. ,
Conversion of trimmed NURBS surfaces to Catmull???Clark subdivision surfaces, Computer Aided Geometric Design, vol.31, issue.7-8, pp.31-38, 2014. ,
DOI : 10.1016/j.cagd.2014.06.004
Anisotropic triangular meshing of parametric surfaces via close packing of ellipsoidal bubbles, Proc. 6th International Meshing Roundtable, pp.375-390, 1996. ,
Interleaving delaunay refinement and optimization for practical isotropic tetrahedron mesh generation, ACM Trans. Graph, vol.28, issue.3, pp.75-76, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00359288
Advancing front surface mesh generation in parametric space using a Riemannian surface definition, Proc. 7th International Meshing Roundtable, pp.429-445, 1998. ,
