THE TRANSFORMATION OF POISSON, BINOMIAL AND NEGATIVE-BINOMIAL DATA, Biometrika, vol.35, issue.3-4, pp.246-254, 1948. ,
DOI : 10.1093/biomet/35.3-4.246
???Finite-Element??? Displacement Fields Analysis from Digital Images: Application to Portevin???Le Ch??telier Bands, Experimental Mechanics, vol.404, issue.3, pp.789-803, 2006. ,
DOI : 10.1007/s11340-006-9824-8
A Dissipation Gap Method for full-field measurement-based identification of elasto-plastic material parameters, International Journal for Numerical Methods in Engineering, vol.22, issue.5-6, pp.685-704, 2012. ,
DOI : 10.1002/nme.4287
Effect of interpolation on noise propagation from images to DIC displacement maps, International Journal for Numerical Methods in Engineering, vol.50, issue.1, p.2016 ,
DOI : 10.1002/nme.5212
URL : https://hal.archives-ouvertes.fr/hal-01255944
Interface debonding characterization by image correlation integrated with Double Cantilever Beam kinematics, International Journal of Solids and Structures, vol.55, pp.79-91, 2015. ,
DOI : 10.1016/j.ijsolstr.2014.06.012
Optimized Patterns for Digital Image Correlation, Proceedings of the 2012 Annual Conference on Experimental and Applied Mechanics, pp.239-248, 2013. ,
DOI : 10.1007/978-1-4614-4235-6_34
Patch-Based Nonlocal Functional for Denoising Fluorescence Microscopy Image Sequences, IEEE Transactions on Medical Imaging, vol.29, issue.2, pp.442-454, 2010. ,
DOI : 10.1109/TMI.2009.2033991
URL : https://hal.archives-ouvertes.fr/inria-00541082
Applications of digital-image-correlation techniques to experimental mechanics, Experimental Mechanics, vol.1, issue.3, pp.232-244, 1985. ,
DOI : 10.1007/BF02325092
Controlling Stress Intensity Factor Histories with Digital Images, Experimental Mechanics, vol.47, issue.13, pp.305-314, 2014. ,
DOI : 10.1007/s11340-013-9790-x
URL : https://hal.archives-ouvertes.fr/hal-00947480
Global 2D digital image correlation for motion estimation in a finite element framework: a variational formulation and a regularized, pyramidal, multi-grid implementation, International Journal for Numerical Methods in Engineering, vol.195, issue.37, pp.96739-762, 2013. ,
DOI : 10.1002/nme.4577
Practical Poissonian-Gaussian Noise Modeling and Fitting for Single-Image Raw-Data, IEEE Transactions on Image Processing, vol.17, issue.10, pp.1737-1754, 2008. ,
DOI : 10.1109/TIP.2008.2001399
Identification of a set of macroscopic elastic parameters in a 3D woven composite: Uncertainty analysis and regularization, International Journal of Solids and Structures, vol.55, pp.2-16, 2015. ,
DOI : 10.1016/j.ijsolstr.2013.12.023
URL : https://hal.archives-ouvertes.fr/hal-01166765
Full-field measurements and identification in solid mechanics, 2013. ,
DOI : 10.1002/9781118578469
Anniversary Article: Effect of Sensor Noise on the Resolution and Spatial Resolution of Displacement and Strain Maps Estimated with the Grid Method, Strain, vol.22, issue.1, pp.1-27, 2014. ,
DOI : 10.1111/str.12070
An Intermediate Course in Probability, 2009. ,
Radiometric CCD camera calibration and noise estimation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.16, issue.3, pp.267-276, 1994. ,
DOI : 10.1109/34.276126
Digital Image Correlation: An experimental mechanics tool, LMT- Cachan. Internal report ,
Comparison of Local and Global Approaches to Digital Image Correlation, Experimental Mechanics, vol.39, issue.8, pp.1503-1519, 2012. ,
DOI : 10.1007/s11340-012-9603-7
URL : https://hal.archives-ouvertes.fr/hal-00750756
CCD Arrays Cameras and Displays, 1998. ,
International vocabulary of metrology ? Basic and general concepts and associated terms (VIM), BIPM, vol.200, 2012. ,
Error Assessment in Stereo-based Deformation Measurements, Experimental Mechanics, vol.46, issue.3, pp.423-441, 2011. ,
DOI : 10.1007/s11340-010-9450-3
Quality assessment of speckle patterns for digital image correlation, Optics and Lasers in Engineering, vol.44, issue.11, pp.1132-1145, 2006. ,
DOI : 10.1016/j.optlaseng.2005.10.004
Estimation of Elastoplastic Parameters via Weighted FEMU and Integrated-DIC, Experimental Mechanics, vol.48, issue.2, pp.105-119, 2015. ,
DOI : 10.1007/s11340-014-9888-9
URL : https://hal.archives-ouvertes.fr/hal-01166755
Image restoration with noise suppression using a multiresolution support, Astronomy and Astrophysics, vol.112, pp.179-189, 1995. ,
On image gradients in digital image correlation, International Journal for Numerical Methods in Engineering, vol.49, issue.3, pp.243-260, 2016. ,
DOI : 10.1002/nme.4971
Comparison of subset-based local and finite element-based global digital image correlation, Experimental Mechanics, pp.1-15, 2015. ,
Equivalence of digital image correlation criteria for pattern matching, Applied Optics, vol.49, issue.28, pp.5501-5509, 2010. ,
DOI : 10.1364/AO.49.005501
Study on subset size selection in digital image correlation for speckle patterns, Optics Express, vol.16, issue.10, pp.7037-7048, 2008. ,
DOI : 10.1364/OE.16.007037
High-Accuracy 2D Digital Image Correlation Measurements with Bilateral Telecentric Lenses: Error Analysis and Experimental Verification, Experimental Mechanics, vol.44, issue.1, pp.1719-1733, 2013. ,
DOI : 10.1007/s11340-013-9774-x
Systematic errors in two-dimensional digital image correlation due to lens distortion, Optics and Lasers in Engineering, vol.51, issue.2, pp.140-147 ,
DOI : 10.1016/j.optlaseng.2012.08.012
Multiscale Displacement Field Measurement Using Digital Image Correlation: Application to the Identification of Elastic Properties, Experimental Mechanics, vol.51, issue.2, pp.121-137, 2015. ,
DOI : 10.1007/s11340-014-9872-4
URL : https://hal.archives-ouvertes.fr/hal-00949038
A dual domain decomposition method for finite element digital image correlation, International Journal for Numerical Methods in Engineering, vol.56, issue.2, pp.1670-1682, 2015. ,
DOI : 10.1002/nme.4868
URL : https://hal.archives-ouvertes.fr/hal-01094665
PRODUCING AND TRANSFERRING LOW-SPATIAL-FREQUENCY GRIDS FOR MEASURING DISPLACEMENT FIELDS WITH MOIRE AND GRID METHODS, Experimental Techniques, vol.21, issue.5, pp.23-26, 2004. ,
DOI : 10.1007/BF02327139
A fully integrated noise robust strategy for the identification of constitutive laws from digital images, International Journal for Numerical Methods in Engineering, vol.199, issue.21-22, pp.631-660, 2010. ,
DOI : 10.1002/nme.2908
Experimental investigation of localized phenomena using digital image correlation, Philosophical Magazine, vol.364, issue.28-29, pp.28-293339, 2008. ,
DOI : 10.1002/nme.849
Extended digital image correlation with crack shape optimization, International Journal for Numerical Methods in Engineering, vol.47, issue.2, pp.248-272, 2008. ,
DOI : 10.1002/nme.2070
An extended and integrated digital image correlation technique applied to the analysis of fractured samples, European Journal of Computational Mechanics, vol.18, pp.3-4285, 2009. ,
Optimal and noise-robust extraction of Fracture Mechanics parameters from kinematic measurements, Engineering Fracture Mechanics, vol.78, issue.9, pp.1827-1845, 2011. ,
DOI : 10.1016/j.engfracmech.2011.01.012
Stress intensity factor measurements from digital image correlation: post-processing and integrated approaches, International Journal of Fracture, vol.40, issue.1, pp.141-157, 2006. ,
DOI : 10.1007/s10704-006-6631-2
URL : https://hal.archives-ouvertes.fr/hal-00013818
Image correlation for shape, motion and deformation measurements: Basic Concepts, Theory and Applications, 2009. ,
DOI : 10.1007/978-0-387-78747-3
Sensor Noise Modeling by Stacking Pseudo-Periodic Grid Images Affected by Vibrations, IEEE Signal Processing Letters, vol.21, issue.4, pp.432-436, 2014. ,
DOI : 10.1109/LSP.2014.2304570
URL : https://hal.archives-ouvertes.fr/hal-00955709
Measuring the Noise of Digital Imaging Sensors by Stacking Raw Images Affected by Vibrations and Illumination Flickering, SIAM Journal on Imaging Sciences, vol.8, issue.1, pp.611-643, 2015. ,
DOI : 10.1137/140977035
URL : https://hal.archives-ouvertes.fr/hal-01133358
On noise reduction in strain maps obtained with the grid method by averaging images affected by vibrations, Optics and Lasers in Engineering, vol.66, pp.210-222, 2015. ,
DOI : 10.1016/j.optlaseng.2014.09.013
URL : https://hal.archives-ouvertes.fr/hal-01075764
Computing the Uncertainty of the 8 point Algorithm for Fundamental Matrix Estimation, Procedings of the British Machine Vision Conference 2008, pp.965-974, 2008. ,
DOI : 10.5244/C.22.96
URL : https://hal.archives-ouvertes.fr/inria-00319704
The effect of out-of-plane motion on 2D and 3D digital image correlation measurements, Optics and Lasers in Engineering, vol.46, issue.10, pp.746-757, 2008. ,
DOI : 10.1016/j.optlaseng.2008.05.005
Application of an optimized digital correlation method to planar deformation analysis, Image and Vision Computing, vol.4, issue.3, pp.143-150, 1986. ,
DOI : 10.1016/0262-8856(86)90057-0
Reduction of Noise-Induced Bias in Displacement Estimation by Linear Off-Pixel Digital Image Correlation, Strain, vol.36, issue.2, pp.158-166, 2013. ,
DOI : 10.1111/str.12023
Quantitative Error Assessment in Pattern Matching: Effects of Intensity Pattern Noise, Interpolation, Strain and Image Contrast on Motion Measurements, Strain, vol.47, issue.2, pp.45160-178, 2009. ,
DOI : 10.1111/j.1475-1305.2008.00592.x
On Error Assessment in Stereo-based Deformation Measurements, Experimental Mechanics, vol.51, issue.4, pp.405-422, 2011. ,
DOI : 10.1007/s11340-010-9449-9
Statistical Analysis of the Effect of Intensity Pattern Noise on the Displacement Measurement Precision of Digital Image Correlation Using Self-correlated Images, Experimental Mechanics, vol.43, issue.6, pp.47701-707, 2007. ,
DOI : 10.1007/s11340-006-9005-9
A Self Adaptive Global Digital Image Correlation Algorithm, Experimental Mechanics, vol.48, issue.6, pp.361-378, 2015. ,
DOI : 10.1007/s11340-014-9946-3
Lens distortion correction for digital image correlation by measuring rigid body displacement, Optical Engineering, vol.45, issue.2, p.23602, 2006. ,
DOI : 10.1117/1.2168411
