LARGE DEVIATIONS AND CONCENTRATION INEQUALITIES FOR THE ORNSTEIN-UHLENBECK PROCESS WITHOUT TEARS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Statistics and Probability Letters Année : 2017
Our goal is to establish large deviations and concentration inequalities for the maximum likelihood estimator of the drift parameter of the Ornstein-Uhlenbeck process without tears. We propose a new strategy to establish large deviation results which allows us, via a suitable transformation, to circumvent the classical difficulty of non-steepness. Our approach holds in the stable case where the process is positive recurrent as well as in the unstable and explosive cases where the process is respectively null recurrent and transient. Notwithstanding of this trichotomy, we also provide new concentration inequalities for the maximum likelihood estimator.
OUWTV3.pdf (171 Ko) Télécharger le fichier
hal-01270164 , version 1 (05-02-2016)
Bernard Bercu, Adrien Richou. LARGE DEVIATIONS AND CONCENTRATION INEQUALITIES FOR THE ORNSTEIN-UHLENBECK PROCESS WITHOUT TEARS. Statistics and Probability Letters, 2017, 123, ⟨10.1016/j.spl.2016.11.030⟩. ⟨hal-01270164⟩
Relations
Collections
CNRS IMB
94 Consultations
135 Téléchargements
